Canada Serving Canada.
Bose CD player skipping?
Old Jan 5, 2009 | 08:01 PM
XuperXero's Avatar
Very common problem with bose systems on a lot of cars. They just dont work in cold climate for some reason.
Old Jan 5, 2009 | 08:08 PM
edvy's Avatar
i was once told by a audio technicial the followings:
all the oem deck arent cd-r competible, so let say, if u r running original cd tracks with a cd lens giving a power level of 2/10 compare to 10/10 running a cd-r. the player's lens will die faster if you are running cd-r all the time. in the 1st couple of years, the cd player's lens will be working fine but its also temperature variant. That the lazer on the len wont be able to shoot thru the cd, and it will starts acting up. Thats why this problem only exist in the cold weather. Plus, this problem will only get worse and doesnt worth a fix.
I think it is about time for u all(including myself) to shop for a aftermarket audio player. Which all aftermarket brands are made cd-r compatible after yr 2004.
Old Jan 5, 2009 | 09:28 PM
ScreaminG's Avatar
I have an Eclipse AVN DVD Navigation head unit that works fine with the stock speakers and AMP. Sound quality is crisp.
Old Jan 6, 2009 | 09:00 AM
togee's Avatar
I've had ongoing problems with the CD unit. Pauses for a second or more every so often. Now that I think about it, it does seem to be worse in cold weather. I've had the CD unit replaced twice under warranty, in 4 years of owning the car. The current one has started doing it again. I don't use CD-R in the unit.
Old Jan 15, 2009 | 04:57 PM
espiegs's Avatar
It was definitely the cold weather. I put a fresh warm CD from the house and it worked fine. The other cold ones skipped, until the car warmed up. What a pain! Bring on Spring!!!
Old Dec 14, 2009 | 11:39 AM
Diana Prince's Avatar
Thank goodness for this site yet again. Not sure why I feel comforted to know that others are experiencing the same problem I am, when I wouldn't want anyone to go through this whole CD skipping fiasco. That said I am glad it is not just me. I will start bringing my CD's inside at night and think about installing another unit. Thanks all.
Old Jan 3, 2010 | 04:38 AM
akoustic's Avatar
any reliable place to get this fixed in Toronto area?
Old Jan 4, 2010 | 10:56 PM
forweareLegion's Avatar
I have the same problem. The solution? To hell with a stereo, get a nice loud exhaust.
Old Jan 12, 2010 | 10:30 AM
akoustic's Avatar
For sure I agree with the cold weather effecting the cd to skip and freeze up. Because mine does it almost every time in winter until my car is warm... however sometimes when I play cd the speakers will fade to one side (either to the right or left). Very strange... it only does that only on CD... help.
Old Apr 15, 2010 | 01:12 PM
lakerschamp2000's Avatar
since this is not cause by wear and tear but technical problem, it should have been a recalled and we can get them fix for free of charge
Old Dec 3, 2012 | 05:49 PM
asadali91's Avatar
Originally Posted by Shawn87
My Bose started to skip too, so I just replaced it with a Kenwood DNX 8120. FYI if you change the unit, you will have to change the amp and speakers as the sound quality takes a sh*t kicking as the Bose system can't adapt to aftermarket. So my skipping problem cost me 3000 for a unit and then probably another 1500 in the spring when i replace the speakers and amp. Damn you BOSE!~!
^ LOLOLOL thats your bad not Bose's
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
JoeMac
Sep 28, 2015 12:28 AM
