Wheel Locks
Wheel Locks
Last year when I bought my car. I remember the dealer showing the wheel lock to me. An hour before I was to pick up the car the dealer decided they would take it out to a tire shop and get some newer tires put on it. Which I appreciated. They just put four brand new brake pads on as well which I supervised.
The thing is when he brought the car back with the tires I think he left the wheel lock at the tire shop. So I am without a tire lock.
My question is can I get this at Canadian Tire or do I have to contact Infiniti to get one?
Are you saying you don't have the actual key to get the wheel lock off or any wheel locks on your car?
If it's the former I would check with the dealer since I believe you'll need the code for the key lock. If you can't find it the dealer will likely have a master key they can use to get them off. They may spring for a new set if you can convince them they lost it.
If it's the latter you can buy wheel locks most anywhere.
I couldn't find my key lock after dealer service once. When I told them I had a new matching key lock a week later. Then I found the lock they had left somewhere else in the car. Now I have two keys.
on
Here, hold on and I'll post a link to a thread I just posted in...
https://g35driver.com/forums/g-spot/...-lock-key.html
on
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
