Canada Serving Canada.
Wheel Spacer mod
Old May 30, 2009 | 05:50 PM
t7n7's Avatar
nice...
Old May 30, 2009 | 06:29 PM
Sylvan lake V35's Avatar
Originally Posted by stclairwest
Do you need extended lugs for going 25 mm?
No you need extened lugs for the ones discussed in this thread. They have a set of lugs attached to the spacer. So you bolt the spacer to your hub with OEM studs and the supplied nuts then you bolt your wheels to the spacer with the spacers studs and your OEM wheel nuts. If you get the spacer with no studs just a spacer with holes drilled in them you would need longer studs (i would recommend going with Ichiba, H&R or eibach ones that have studs on them).
paolojericho11
Sep 11, 2015 07:08 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
sick_sixspeed
Jul 21, 2015 01:59 PM
