Canada Serving Canada.
Swivel-dropped on Coupe 19s
Old Jul 1, 2009 | 12:04 AM
  #61
Texan1's Avatar
Q50 Red Sport 400 RWD
Sent you a PM reply. Btw, I don't think you will have any rubbing issues with 35 series tires. I do have my lips rolled in the rear, but it was not in response to rubbing. I did it before I was lowered as precaution. I think it is pretty much agreed upon that 35 series tires with z/cpe suspension = no rubbing. The only way you would rub is if you had 3 200 pounders in the back and a couple boxes of heavy shiit in the trunk. Even then, you should be ok.
Old Jul 1, 2009 | 10:22 AM
  #62
RBull's Avatar
Rated M
Originally Posted by SwivelHips
^^ It's possible, though they are sport coupe springs, so a little longer than Z springs (debatable, I've measured) and stiffer, 427lb IIRC. I would think that 300km with ~300lbs in the back ought to have settled them by now.
BTW Coach, the tires are BS RE050's front and Falken 452's rear. One or the other is ELL OH DUBYA DEE!! I'll probably get a summer out of them, then replace them in spring, unless I stumble across a wicked deal in the meantime.
You're right. they are a little longer....approx 1/4". Funny thing is I've had them both on and off a few times and there was absolutely no difference in the stance until I cut my mount springs.
Old Jul 3, 2009 | 01:54 PM
  #63
Swivel's Avatar
Moderator
Thanks for the very informative PM!
I'll have to compare to Kevco's car tomorrow and see if there's any difference between my coupe rears and his Z rears in terms of gap.
Old Jul 3, 2009 | 02:17 PM
  #64
KevcoG35's Avatar
I do run a slightly smaller 245 40 18 outback to offset the "reverse rake" and with my 20mm spacers I rub on rolling bumps. Hoping to fix that tonight though. With my tires I bet our gaps are quite similar.
Old Jul 3, 2009 | 02:34 PM
  #65
KevcoG35's Avatar
Also, had to flip my NEW tires on the rear already to even out the wear due to the bad camber damage. fronts are good but I guess a rear camber kit is must for even a small drop.
Old Jul 3, 2009 | 02:56 PM
  #66
Swivel's Avatar
Moderator
^^ Damn, that sucks. Did you get an alignmnt, and what are your rear camber numbers?
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
Th611
Oct 27, 2015 03:48 PM
Kal Hamm
Jul 24, 2015 08:55 AM
