American Speedometer
Now that you mention it I do remember seeing a White sticker with the VIN at the bottom in the drive side door, I cannot recall whether it had "RIV" on it. Is that what you're referring to?
Well there will be the generic label with the original door sticker with tire pressures and weights etc, then the riv one is placed somewhere else on the frame, really only fits above the other one, it is half white and half gray with the same data in kg and kpa instead of psi and lbs.
I remember seeing 2 stickers so chances are that will be it. Thanks once again for all the info. I'll go to the MTO tomorrow to do get the Canadian history on the vehicle and the Carfax report as well. If I have any other questions I will definitely ask you as you have already successfully gone through the process.
Yes, those should be the two stickers. You could probably also call the RIV with the VIN to double check. But getting both histories is a good idea as each carries different data and carfax completely sucks for canadian histories. Hopefully everything works out for you.
