Canada Serving Canada.
Where do I go in GTA for a real transmission oil flush, not just a drain and refill?
Old Jul 24, 2009 | 11:54 AM
Smartidiot's Avatar
Hello Guys,
Can anyone recommend a quality shop in GTA where they can perform a real transmission oil flush (using one of those sucking machine), rather than a simple drain and refill?
Also any ideas how much is the labour gonna cost? (excluding the cost of the transmissoin oil).
Your opinions are appreciated.
Old Jul 24, 2009 | 05:14 PM
blaccG35's Avatar
i would like to know as well...i call simone and got a quote of 83 and change for a tran oil change but i dunno if they use the sucking machine
Old Jul 25, 2009 | 09:37 AM
STCLAIRWEST's Avatar
I need to know too, its almost my time to change it.
Old Jul 25, 2009 | 11:46 AM
knight_yyz's Avatar
There is a procedure that the maxima guy use, I'm sure it would work on the G as well. As long as you have 2 guys and a couple of buckets you can do it yourself. Fill a new clean bucket with the amount of fluid your tranny requires. Have another empty bucket handy that will hold at least that much as well.
Put the car up on jack stands. Disconnect the tranny hoses from the transmission. Put the feed line in the bucket with the fresh fluid. The other line goes in the empty bucket. Start the car and "slowly drive the car and shift through the gears". This will suck the good fluid out of the bucket and send all the crap from the tranny to the empty bucket. Stop the procedure when the fluid starts to come out clean. Hook everything back up, put the car back on the ground on a level surface, double check the level, and top up if necessary. Cost, a 12 pack of beer for your buddy who helped you.
magnetism80
Feb 1, 2019 10:00 AM
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
gatorglaze
Sep 10, 2015 12:03 PM
saskicker32
Aug 11, 2015 02:12 PM
newg37
Jul 26, 2015 09:32 AM
