Canada Serving Canada.
defeated by bolts
Old Sep 3, 2009 | 08:26 PM
Gd35up's Avatar
defeated by bolts
SO today me and my buddy decided to install my z-tube. everything went smoothly up until we tried to put everything back together (cover only). Somehow we managed to break 2 bolts clean off with the other half still inside. How did we install the z-tube flawlessly... but end up messing up the easiest part of the DIY. Now i've got 2 broken bolts inside my engine.
Old Sep 3, 2009 | 08:51 PM
blaccG35's Avatar
which bolt did you break exactly??? cause when i installed my z-tube it was pretty straight forward
Old Sep 3, 2009 | 08:55 PM
Gd35up's Avatar
It's SO straight forward, I don't know what happened. The top 2 bolts just decided to snap CLEAN off. Anyone know how the hell am I going to get that out?
Old Sep 3, 2009 | 09:30 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
What bolts????
..the cover bolts that go into the plenum?
There are ways to remove them.
Old Sep 3, 2009 | 09:35 PM
Gd35up's Avatar
Yep the cover bolts that go into the plenum. They both snapped clean off. Pliers can't get to them anymore, ideas?
Old Sep 3, 2009 | 09:38 PM
InTgr8r's Avatar
Drill & easy out is the normal method.
These may be too small for that.
The other method is drill out & re-tap new threads.
You will need a bottoming tap, since you don't want to go all the way through.
..or just run w/o the cover & refinish the plenum.
Paint or polish.
Old Sep 3, 2009 | 09:45 PM
Gd35up's Avatar
the finished cover looked pretty nice. if i can't get it out, i'll finish the cover. i can't believe i managed to bust the bolts... too much muscle?
Old Sep 3, 2009 | 11:12 PM
Swivel's Avatar
Moderator
Originally Posted by InTgr8r
Looks nice, Ian. Your old G? What kinda paint?
Old Sep 3, 2009 | 11:53 PM
acidjake75's Avatar
I dont do any work on the plenum or anything touching it with out my trusty inch lb torque wrench - been there, done that.. I LOL'd @ too much muscle.. Those are known to break if you dont torque them right..The VQ is "sensitive" (hehe)
Old Sep 4, 2009 | 08:09 AM
Shawn87's Avatar
Easy outs like Ian said... work like a charm!!!!
Invest in a torque wrench... all specs are available to dl in the technical section too !
Old Sep 4, 2009 | 08:17 AM
acidjake75's Avatar
^^^when your playing with 80inch lbs - Thats NOTHING at all..my ft lb torque wrench only went down to 10 so I couldnt use it..Had to get a whole new one to do inch lbs.. best 40 bucks I ever spent
Old Sep 4, 2009 | 08:26 AM
Shawn87's Avatar
This thread reminds me of the 'spacer install' thread a couple months back...
Old Sep 4, 2009 | 08:36 AM
Gd35up's Avatar
Yeah, I should have thought about the torque specs and what not before I started... need to lay off the roids.
Old Sep 4, 2009 | 09:42 AM
TroysG's Avatar
with nuts that aren't essential to holding the engine together I go hand tight plus 1-2 turns with a ratchet to snug it up.
Old Sep 5, 2009 | 12:29 PM
Gd35up's Avatar
LOl yeah lesson learnt. I salvaged 1 of the 2. I guess it's better than nothing.
