Canada Serving Canada.
Camber shims - FREE
Old Oct 1, 2009 | 01:27 PM
Shawn87's Avatar
Camber shims - FREE
I was looking through my garage on the weekend and came across the old camber shims I had from my spc camber kit.
Theres a bevel that im not sure the degree of on them, but I do know when I reversed the shim for the brake without thinking, I scraped the sh*t out of my disc :S Then I figured out what they were for.
I ran the front of my car 3 inchs off the ground, and with the camber kit/shims I was able to run a flat camber setup to save my toyos.
Included is a hub shim and a caliper shim for FRONT end. Maybe be useful for guys who run a lowered setup without a camber kit???
If someone wants they they can have them. If not Im going to throw them out. Wanted to see if someone would use them first.
Located in West Sauga.
Old Oct 1, 2009 | 01:35 PM
G SEDAN's Avatar
if i pay for your lunch and shippign will you ship to CA?
Old Oct 1, 2009 | 01:59 PM
Shawn87's Avatar
I'd like to give to a local first, if not then we can discuss shipping.
Old Oct 1, 2009 | 04:05 PM
Jasonp32's Avatar
Hey Shawn, I'm lowered on Tein Basics with no camber kit. I just have toe and camber bolts on the rear, so, I'm interested!
Old Oct 1, 2009 | 04:07 PM
Shawn87's Avatar
I forgot to put theres are for the front! Does that still help?
Old Oct 1, 2009 | 04:12 PM
Jasonp32's Avatar
Yes, that would help even more! I've lowered the front a little over an inch and the rear about one inch. The camber is much worse in the front than the rear on my car. Will they reduce the amount of front camber on my car? Should they only be used with the SPC front camber kit, or will they reduce the front camber all by themselves?
Old Oct 1, 2009 | 04:15 PM
Shawn87's Avatar
Im not exactly sure their purpose but I know they do something... They are thinner on the front and wider at the back... or maybe its the other way around. I cant remember but they only fit on the hub one way. Ill attach a dwg....
Old Oct 1, 2009 | 04:26 PM
Shawn87's Avatar
The plan view is just pictorial, it kinda goes (Example, not actual dimensions) corner 1 is 1/16", 2 is 1/8", 3 is 3/16, 4 is 1/4...
Old Oct 1, 2009 | 04:32 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
hmmmm....
I might be wrong, but I thought these were for gaining more neg camber.
I always though that camber shims were for track use.
If the A arm is still in the same position (no kit) at the top,
then the shims push the axle further out at the bottom, producing more neg camber.
...can they be used w/o the A arm kit?
Old Oct 1, 2009 | 04:34 PM
Jasonp32's Avatar
Nice CAD drawing! lol! Seriously, it helps and I get the idea. If you can hold on to them for me while I confirm if it will help my situation, I'd really appreciate it.
I'll get back to you tonight.
Thanks...
Old Oct 1, 2009 | 05:35 PM
Polaren's Avatar
I think InTgr8r is correct.
It should increase negative camber, especially based on those drawings.
Old Oct 1, 2009 | 10:11 PM
InTgr8r's Avatar
Just noticed that that sketch is 'PLAN VIEW"
We may be thinking about the orientation the wrong way,
& that cad dwg may be a little misleading.
For these to work,
- one shim goes on the caliper to space it out to the rotor properly.
..for that to work the polar alignment of the shim face would have to be a perpendicular to the center line between the caliper mounting bolts.
The thick part of the shim would be near the caliper.
Old Oct 2, 2009 | 07:46 AM
Shawn87's Avatar
For these to work,
Haha sorry my CAD drawing was a bit rushed, I should have plotted it out in 3D. You could be right, like I said i forget if the thick or thin side is towards the front of the car. I had two sets of camber arms which is why I had two sets of shims. I have honestly no idea what they do, I never installed them myself had a shop do it.
Either way, if someone thinks they are useful they can have them, if not Im just going to chuck them.
Old Oct 2, 2009 | 02:31 PM
Jasonp32's Avatar
I asked Edward at THMotorsports.com. He said, "Jay those work only in conjunction with the camber kit. You can put them on, but it will cause more negative camber for you."
So, thanks anyway Shawn, but I'll have to pass.
Old Dec 26, 2009 | 02:06 PM
SavageHenry's Avatar
I really could use them do you still have them???
