Canada Serving Canada.
Clutch replacement (Canada)
Old Nov 11, 2009 | 08:09 PM
scouzi's Avatar
Was quote a price of $2600 for replacing a clutch at a Nissan dealer (Infiniti dealer is too far away). This seems a bit high to me.
If anyone had their clutch replaced, how much did you pay?
Old Nov 11, 2009 | 09:41 PM
Hossmaxima's Avatar
Go to Simone Performance in Newmarket...or even Advance Powerhouse. The labour is usually around $500, and then you have to source you clutch and you may want a lightened flywheel. I paid about $1200 for everything, I wouldn't spend more than $1500.
Old Nov 11, 2009 | 09:57 PM
Sylvan lake V35's Avatar
Labor is about 6hrs by the book. So you shouldn't pay more than that add the cost of a decent aftermarket clutch/flywheel you should be well under $2000
Old Nov 11, 2009 | 10:19 PM
scouzi's Avatar
Someone else is paying the bill. It`s a standard OEM clutch replacement job. Seems high to me but I don`t really care but it does seem high.
Old Nov 11, 2009 | 11:15 PM
It seems very high, i would see if you could upgrade to a Jim Wolf Tech clutch for an additional cost. if you are into modding at all its a nice upgrade over stock.
Old Nov 12, 2009 | 12:58 PM
canucklehead's Avatar
$2600 is nuts. the OEM clutch disk is not a pricey unit. what parts have you been quoted for? just the disk, or a complete clutch assembly replacement (pressure plate, throw-out bearing, shift fork, flywheel, etc...)?
if you do not plan on moddifying your car than stick with the OEM parts. sure the aftermarket parts are cheaper, and may offer minor performance advantages, but the downside is driveability and noise issues. plus when you go to sell, buyers may not appreciate the hi-po parts.
Old Nov 13, 2009 | 01:04 AM
knight_yyz's Avatar
the disk is only 75 US, but about 175 CDN, go figure. I would personally go with an exedy stage one as the disk is a little bigger for more grip. The Jim wolfe uses the OEM disk.
I paid just over 500 labor at Simone's as well, including taxes and fluids, but i got the frequent flyer discount as I had 2 transmissions done in less than a year.
Old Dec 1, 2009 | 09:37 PM
scouzi's Avatar
It turns out that labour was around $400 but the cover was $700 and the Flywheel was $1750! Ouch.
cbax
Aug 17, 2015 07:41 AM
NemesisGee
Aug 11, 2015 07:10 PM
TurboEE
Jul 31, 2015 10:41 AM
socalg35x
Jul 28, 2015 10:42 AM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
