Canada Serving Canada.
Pedal adjustment
Old Feb 15, 2010 | 03:57 PM
ReD De(V)oN's Avatar
Pedal adjustment
Hey guys I am just curious as to whether it is possible to get our pedal heights adjusted. The reason I ask is because I think I would like to raise my gas pedal a little bit just to help with rev match down shifts, just feels a little low and I have to come down too hard on the brake to get a good blip on the throttle. My foot isn't very wide so this would definitely help.
I searched and didn't find anything and hope this is not too much of a rediculous question.
Thanks guys
Old Feb 15, 2010 | 04:09 PM
Deepdiver's Avatar
^ I am curious about this adjustment as well. My resolve however is opposite as I wish my gas pedal was lower or brake pedal was higher. I would prefer your situation because you're likely to be under hard braking in track/aggressive situations.
Old Feb 15, 2010 | 05:40 PM
RBull's Avatar
Rated M
I found the set up not too bad for track use, since you're deeper on the brake pedal than on the street.
Old Feb 15, 2010 | 11:35 PM
4DGS's Avatar
Aren't these transmissions syncro'd? Aka, no rev matching needed?
Old Feb 15, 2010 | 11:48 PM
nghiars's Avatar
still got to on down shifts
Old Feb 15, 2010 | 11:52 PM
4DGS's Avatar
Ehh, I don't drive my Z with much hate, usually just slide neutral when slowing.
I thought that's what the syncro transmission was for...
Old Feb 16, 2010 | 02:12 AM
Deepdiver's Avatar
you can push/pull the shifter into gear, but once you let out the clutch, the rev's need to be matched so everything is smooth and you don't result in a rapid forward weight transfer.
Old Feb 16, 2010 | 08:31 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
I searched and didn't find anything and hope this is not too much of a ridiculous question.
Thanks guys
Probably the easiest way is to add a layer to the gas pedal.
e.g. in my BMW, I installed custom alum. pedals. Ultimate pedals
Installation lowers the brake & clutch while raising the throttle.
- brake & clutch; rubber is removed & alum bolted directly. (alum thinner than rubber)
- Throttle was layered on top of existing.
Overall change wasn't much, but it made H&T much easier.
Old Feb 17, 2010 | 03:54 PM
Thanks InTgr8r I guess I will have to improvise in this case, kind of sucks. Ah well thanks for the idea anyways I may just end up trying it and hope it helps.
Old Feb 17, 2010 | 05:01 PM
STCLAIRWEST's Avatar
Hey Garret whats your plans for the demon come spring?
Old Feb 17, 2010 | 09:16 PM
6MTKeith's Avatar
I found the geometry on my pedals off too when i got my car. For me though, I found the clutch pedal too far forward as I like to sit a bt further back. Think my left legs short. I made a ~3/8 spacer wth a clone of the clutch pedal behind the clutch rubber pad.
I had been in an auto for a few years before too though.
Old Feb 19, 2010 | 04:38 PM
Hehe you'll just have to wait for the supermeet to see my friend, but I promise it will be nice, mods are already in motion.
Old Feb 23, 2010 | 04:45 PM
rzua5's Avatar
*Ahem* trust me, Garrett's car is gonna be SICCCKKKK~~
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
Fox843
Nov 7, 2015 05:43 PM
AL8782
Oct 3, 2015 10:26 AM
master111
Sep 25, 2015 08:32 PM
