Canada Serving Canada.
My Carbon Fiber Wrap just came in!
Old Mar 27, 2010 | 03:54 PM
davidxu's Avatar
Alright, i did my door handles today, and attempted to do my shifter ****. Probably do the center console later on today. Here's some pics for now.
Backside of the wrap.
Front:
Pics of Installed on car:
Front Pass
Front Driver
Rear Pass
Rear Driver
Shifter ****:
Also, it seems that this fabric is actually waterproof:
Even though its waterproof, the fact that it is fabric and not vinyl will make me NOT recommend this for exterior use.
*Updated first post with pics*
If you would like me to get this done for you, pm me
Old Mar 27, 2010 | 04:16 PM
STCLAIRWEST's Avatar
YOYO do this for me....Im tired of the "wood" colour on mines.
How long did it take you?
Old Mar 27, 2010 | 06:35 PM
gshock's Avatar
AMAZINGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGG
u got skillsssssssssssssssssss
Old Mar 27, 2010 | 08:37 PM
davidxu's Avatar
ok. I finished the center console. It may look good from pics but it took sooooo long. buttons ruining the side of the wraps, button becoming stuck, wrap not lining up with other parts.... etc etc. such a PITA. so worth it when its done though!!
pics:
looks SO much better than before.
Total work time is about 6 hours. 1-1.5 hour on 4 door pulls, 4.5 - 6 hours on center console.....
Old Mar 28, 2010 | 01:51 AM
gshock's Avatar
damn that looks so goodd, prob looks even better in personnn,
Old Mar 28, 2010 | 01:55 AM
Hossmaxima's Avatar
Great job David! Looks way better than the woodgrain.
Old Mar 28, 2010 | 08:08 AM
GEE35FX's Avatar
Nice job, it does look a lot better than the woodgrain.
Old Mar 28, 2010 | 08:10 AM
RBull's Avatar
Rated M
Impressive job. Looks great.
Old Mar 28, 2010 | 09:13 AM
jwolfpk's Avatar
looks sooo much better than woodgrain...where did you get the fabric??
Old Mar 28, 2010 | 09:19 AM
davidxu's Avatar
eBay..
Old Mar 28, 2010 | 09:27 AM
jwolfpk's Avatar
thanks.. do you think a yard of it would be enough to do coupe door handles and the center console?
Old Mar 28, 2010 | 09:29 AM
headshot's Avatar
I would guess the thickness is what causing the buttons to stick on the inside of the lips. Can you sand down the material inside the lip were the buttons pop through? You wouldn't be able to see it once put back together.
Just a thought
Old Mar 28, 2010 | 09:54 AM
davidxu's Avatar
^ i thought of that, but since i had to use the car shortly after i put it back, i just didnt bother with it. Miraculously though, the buttons are now not stuck anymore
jwolfpk: yes, 1 yard will definitely be enough.
Old Mar 28, 2010 | 04:21 PM
G35thrilla's Avatar
that looks real tight. maybe try is when i get the double din kit. does the thickness of the fabric offset all the parts a lot?
thanks in advance
Old Mar 28, 2010 | 04:27 PM
  #30
davidxu's Avatar
it offsets a bit. The fabric i used was 0.4mm thick.
