Canada Serving Canada.
RESTORE and VQ engines do NOT mix!!
Old Jan 5, 2011 | 05:14 PM
Sylvan lake V35's Avatar
Originally Posted by lilindienplaya
So was this thick sludge just from the RESTORE reacting with the synthetic oil?, or was it actually doing its job and freeing up all the gunk inside the engine? i mean i can see where if the RESTORE got all the gunk off the crevices and all that it would mix in the oil and make it very thick and kinda just stay where it lands I.E. the cam sensor (which has no moving parts just senses pulses so once you change the oil it should be fine from now on).
Restore itself is quite thick,is it not I haven't used it in years. The cam sensors were not effected if you have ever seen where they sit they are not in any oil and would have minimal contact with the oil. They don't sence pulses either they are magnetic and the cams have multiple grooves cut out in a certain order and the sensors read that. The issue is all of the small orifices may not become plugged but with the thick restore the pressure be.comes too high and they do not allow the VTC to function properly.
Old Jan 5, 2011 | 05:23 PM
JOKER's Avatar
CLUB MODERATOR
what a well known fact is......if it aint broke.........don't fix it
glad you got out of it ok.
Old Jan 5, 2011 | 05:58 PM
Freeman186
Sep 6, 2023 10:07 AM
wuzz-upp
Oct 3, 2015 04:21 PM
Joe Gargano
Sep 18, 2015 11:17 AM
AuAltima3.5
Sep 13, 2015 10:53 AM
Jnm07
Sep 5, 2015 01:16 AM
