Canada Serving Canada.
Winter Tire Time ?
Old Nov 16, 2010 | 04:30 PM
  #91
RBull's Avatar
Rated M
^got some for my snow blower. Used to run that too when I had the coupe.
Old Nov 16, 2010 | 08:31 PM
  #92
audiophool's Avatar
Coupes and snow FTW... not. Blizzak LM-25 and VLSD = meh. That said, it's no worse than any of the RWD BMWs I've had.
Old Nov 16, 2010 | 10:24 PM
  #93
msommers's Avatar
Yeah it's nothing great, I couldn't imagine driving without winters though! On my way home from work I ended up turning off the traction control. Anytime I finally get going it slips slightly and decelerates. Much easier to predict and control for me.
Old Nov 16, 2010 | 11:54 PM
  #94
bomberman447's Avatar
Looks like I will be installing my favorite winter mod tonight.......trunk gravel. Got stuck trying to get into my driveway at low speed and had to back down the culdesac to get going again
Old Nov 17, 2010 | 12:21 AM
  #95
musti82's Avatar
do we really need one (i have stock 5at coupe) i mean trunk gravel, if yes, what's an easy fix(what do u use?) maybe i should put one of my stock rims
Old Nov 17, 2010 | 12:25 AM
  #96
Well it helps a bit with the traction and the back end stepping out. Not perfect, but I appreciate the little extra it provides. I just have three bags of the gravel from home depot. I believe they are around 50lbs each.
Old Nov 17, 2010 | 12:52 AM
  #97
6MTKeith's Avatar
If i were you I would switch vdc off the minute you get in the car. It WILL get you stuck on a hill, on/off ramp, parking entrance etc. Its the worst trac control in existance for snow/ice.
Old Nov 17, 2010 | 01:00 AM
  #98
Mark E's Avatar
size help....
hey guys, im looking at buying winter tires/rims off a guy he is selling 1 month old winter tire/rim set (like new). I want to know before i commit and make an offer that this set will work fine on my car. He had them on a 06'
g35x and i want to use them on my 07' g35x, details: Vredestein winter tires 215/55/R17 on Eagle alloy rims. Rims have 2 bolt patterns that can fit many model of vehicles.
My 07' stock size 225/55r17 and will there be an issue going to a 215/55r17 size?
Price asking firm is $950.00 , he paid $1290.00 new
Thx Mark
Old Nov 17, 2010 | 09:46 AM
  #99
6MTKeith's Avatar
They will spin a fragment faster and ground clearence would be less, but not enough to make a difference. Used tires are used tires though, doesn't seem like too good a discount. The Vredesteins are supposed to be a great ire though. I find people tend to think their tires are in a lot better shape than they are. Or at least try to make you think that. See them first.
Old Nov 17, 2010 | 10:22 AM
  #100
musti82's Avatar
I live in downtown so snow gets cleared pretty fast, so im more concerned about ice and relatively thin snow that's why i got the michelin x-ice 2s, since they seem like having better grip on icy conditions.
by the way, what's ideal tire pressure for winter tires?
Thanks in advance.
Old Nov 17, 2010 | 10:26 AM
  #101
GEE35FX's Avatar
I would run them at 34-35psi
Old Nov 17, 2010 | 11:39 AM
  #102
fabb's Avatar
gotta question...i got winter tires and rims given to me..but the guy that had them before me had them on a 06 g35 coupe without brembos..i have an 04 with brembos so as i went to put them on i noticed they dont fit..so instead of buying new rims i was thinking of just keeping my 25mm spacers through the winter..any suggestions?
Old Nov 17, 2010 | 12:24 PM
  #103
35bills's Avatar
I would use bags of kitty litter instead of the gravel...In case you do get stuck, you can use the the kitty litter as extra traction especially on ice!!!!
Try Petsmart stores for large bags.
Old Nov 17, 2010 | 12:38 PM
  #104
InTgr8r's Avatar
Staff ALUMNI (retired)
That should be no problem.
Just make sure to coat both faces of the spacer with anti-seize.
Old Nov 17, 2010 | 06:03 PM
  #105
6MTKeith's Avatar
I find gravel to be far better as a traction aid. Litter would be great if you ever leak anything though. Might as well mix a little salt in there too.
