Canada Serving Canada.
Adrenaline Motorsports broken into and burned down
Old Dec 23, 2010 | 10:32 PM
4DGS's Avatar
Everyone keep your eyes out on Kijiji or whatever for these parts.
This is brutal and I can't believe it has happened.
Original message from owner
Originally Posted by CressAdrenaline
Please sticky this thread!!
As you may have heard, my shop was robbed and then set on fire on Aug 2. The thieves made off with a HUGE load of performance parts, and nearly all my hand tools and equipment. It’s now up to the Supra community to ensure that the criminals are brought to justice and if caught quickly, the parts will be returned to me.
Please look at this list and keep an eye out for these parts – whoever is selling them did NOT pay for them. I did.
Here is a list of most of the parts/tools stolen from my shop before it was torched. I need your help to catch these a$$holes. If it's too good a deal to be true, then it likely is my stuff.
Someone is going to brag about this to someone at a party, or offer to sell you something that is not theirs to sell. Please pass any and all possible leads to Detective Sgt Matthew Jeary of the Waterloo Regional Police Service at 519-589-6711 or anonymously to Waterloo Police Crimestoppers at 1-800-222-TIPS or online at http://www.waterloocrimestoppers.ca/...page=submittip.
You can also text message your tip in. Send your message to “CRIMES” (274637), and put “TIP152” at the beginning of the body of the message. Your messages are secure and anonymous.
Please help to bring the thieves to justice and get my parts returned. Thank you. Also, feel free to copy this message and list to other forums of which you are a member - we're bound to catch the ****** trying to sell the parts.
MKIV SUPRA PARTS - NEW IN THE BOX MODEL
1 kit TRD Replica WideBody Kit for 1993-98 Supra
1 pc TRD FG Replica Wing,
1 pc Seibon Carbon Fiber Hood for 1993-98 Style, TRD Style
1 pc Defi Control Unit II - Version 2 DF05002
1 pc Defi BF ** US SPEC ** Boost Gauge, 60mm, White DF04303
1 pc Defi BF **US Spec** Oil Pressure Gauge, 60mm, White Imperial DF04403
1 pc Defi BF **US Spec** Oil Temperature Gauge, 60mm, White Imperial DF04603
1 pc Defi BF **US Spec** Water Temperature Gauge, 60mm - White Imperial DF04703
1 pc Defi BF **US Spec** Fuel Pressure Gauge, 60mm, White Imperial DF04503
1 pc Defi BF ** US SPEC ** EGT Gauge, 60mm, White DF04803
1 set 4300K Xtreme HID Conversion Kit for 1993-98 Supra - high beam XT-AK-9005
1 set 4300K Xtreme HID Conversion Kit for 1993-98 Supra - low beam XT-AK-9006
1 pc MVP Motorsports Turbo Blanket, Black
1 pc TRD Oil Cap for 1993-98 Supra
1 pc Mishimoto Silicone Hose Kit for 93-98 Toyota Supra Turbo, Blue MMHOSE-SUP-93BL
1 pc Fluidyne Radiator for 1993-98 Supra FHP11-93SUPRA
2 pc Power Division (GSC) Stage 2 Camshafts for 1993-98 Supra TT 6030S2
1 pc Tein EDFC Controller Unit EDK04-K4469
1 pc Tein EDFC Motor Kit EDK05-12120
1 pc Powerhouse Racing Street/Race Intake Manifold
1 pc Powerhouse Racing Modified Oil Pump for 1993-98 Supra
1 pc Powerhouse Racing Breather Kit for LHD 1993-98 Supra, Red & Blue Fittings
2 pc Powerhouse Racing Stainless Steel Clutch Line for 1993-98 Supra M/T
1 pc Powerhouse Racing Upper Rad Pipe for 1993-98 Supra, Polished Stainless
1 pc Powerhouse Racing Timing Belt Tensioner Bracket for 1993-98 Supra
1 pc MVP Motorsports Upper Shock Arm for 1993-98 Supra 6-speed T-4002
1 pc MVP Clutch Master Cylinder Reservoir Cover, Polished T-4036
1 pc MVP Motorsports Aluminum Igniter Cover for 1993-98 Supra T-4035
1 pc TTC Brake / Power Steering Cap, Polished T-4032
1 pc TTC Performance Water Pump Pulley Cover, Aluminum Finish T-4000-TC
1 pc TTC Supra Script Windshield Washer Fluid Reservoir Cover, Polished T-4033-TC
1 pc TTC Performance ABS Cover for 1993-98 Supra T-8120-TC
1 pc TRD Oil Cap for 1993-98 Supra 12180-SP020
1 pc TRD 160 Degree Thermostat for 1993-98 Supra 16340-SP020
1 pc Unorthodox Racing Idler Pulley for 1993-98 Supra 11270712
1 pc Unorthodox Racing Alternator Pulley for 1993-98 Supra, Silver 11230712
1 pc Unorthodox Racing Power Steering Pulley for 1993-98 Supra, Silver 11240712
1 pc Unorthodox Racing Water Pump Pulley for 1993-98 Supra, Silver 11250712
2 pc 2 AP Engineering Shifter Bushing Kit for 1993-98 Supra 6-speed & 5-speed
1 pc HKS Titanium Exhaust for 1993-98 Supra Twin Turbo 3108-RT001
2 pc HKS Version 3 Universal Blow Off Valve Kit 71007-AK001
2 pc HKS SSBOV Flange, Aluminum 1410-SA003
1 pc Max Air Airbox with no pre-cut hole
1 pc RPS Carbon/Carbon Twin Disc Clutch for 1993-98 Supra TT BC2PK-22170-AL
2 pc StopTech 14" Big Brake Kit for 1993-98 Supra TT, 4-Piston Black Calipers, Slotted Rotors, Front 83.857.4700.51
2 pc StopTech 14" Big Brake Kit for 1993-98 Supra TT, 4-Piston Black Calipers, Slotted Rotors, Rear 83.857.0047.51
1 pc Apex Overflow Tank 573-A001
1 pc Greddy Oil Cooler for 1993-98 Supra, 16 Row, Includes Remote Filter 12014405
1 pc Titek Carbon Fiber Radiator Cooling Plate for 1993-98 Supra - Dry CFP-84001D
2 pc Titek Magnetic Drain Plug for Toyota and Nissan, M12xP1.25 MAGDP-RD
1 pc AEM 6-in-1 UEGO Gauge 30-4100
1 pc AEM Water/Meth Injection Kit 30-3000
1 pc AEM Inline Water Injection Filter 30-3003
1 set ARP Main Stud Kit for 1993-98 Supra TT 203-5405
1 set ARP Rod Bolts for 1993-98 Supra 203-6005
1 set ACL Race Series Rod Bearing Set for 1993-98 Supra TT - Standard 6B8100H-STD
1 set ACL Race Series Main Bearing Set for 1993-98 Supra TT - Standard 7M8103H-STD
1 set ACL Race Series / X Series Thrust Washer Set for 1993-98 Supra TT - Standard 2T8103-STD
2 set R2 Racing Steering Rack Bushing Kit for 1993-98 Supra 800-ST100
1 pc "Secret Carbon" Carbon Fiber Airbag Gauge Pod, LHD
1 pc MVP Triple A-Pillar Mount for 1993-98 Supra, 60mm
MISCELLANEOUS UNIVERSAL, MKII, MKIII/MKIV PARTS, NEW or USED
MKII
4 set Addco sway bars 745/375 sets
1 pc Cusco MKII front strut brace blue
2 set Ground Control 8010.01 MKII coilover kits
MKIV
1 pc Toyota 2JZGTE engine w/T78 turbo, braided fuel line, billet fuel rail, 720cc injectors, FPR
1 pc Toyota V160 transmission Getrag 6 speed
1 pc RPS sport clutch w/6 puck disc, new
1 pc RPS Syn-R-G flywheel segmented surface, newly rebuilt, like new
1 pc TIEN HA coilover green, near new, one unit missing spring perches
1 pc TRD MKIV front strut brace
2 pc Cusco MKIV front strut brace blue, one with Japanese price sticker
1 pc Toyota MKIV wing green
1 pc Toyota MKIV wing red
UNIV
2 pc Sparco Milano race seat grey Alcantra suede, mint cond
4 pc Enkei wheel 18x8, 18x9 5 thin spoke silver rims w/tires, brush painted black behind spokes, Supra decal on spoke
4 pc BSA 215 wheel 18x8 (2) 18x9 (2) black 10 spoke center, polished lip w/new Falken tires
4 pc BSA 215 wheel 18x8 (2) (unmounted, in boxes) 18x10 (2) black 10 spoke center, polished lip w/new BFG KDW tires
1 pc APEX-i S-AFC ECU fuel computer
1 pc APEX-i AVC-R ECU turbo boost controller
1 pc Blitz Dual-SBC Spec-R ECU turbo boost controller
1 pc Setrab oil cooler silver 4x4x30", blue -10AN caps
50 pc Samco silicone IC couplers, various sizes, new, no pkge
1 set Addco sway bars 385/776 set
4 set 8mm, 10mm, 15mm alum wheel spacer sets, with Japanese price tags
TOOLS
2 Mastercraft tool cabinet 2 units, 5'H, all tools
1 Rigid shop vac 24"dia w/access
1 Mastercraft battery charger 24" H, floor model w/wheels, 6 settings, black
8 sets Mastercraft sockets 3/8" & 1/2" drive Metric deep chrome and impact sockets
4 sets Mastercraft wrenches Gearwrench Metric open end ratcheting wrenches
Central Hydraulics 20 ton floor hydraulic press, orange
1 Powerfist floor jack 2.5 TON, orange
4 Powerfist axle stands yellow 2 ton capacity
1 Powerfist engine stand yellow 1250lb
Wen polisher blue
Craftsman angle buffer,black, missing side handle
Hand tools in cabinet consist of STC torque wrenches, valve seal service tools, multimeters, hammers, screwdrivers, Allen key sets, sockets, COP coil pack tester, torque angle gauge, compression tester, thread chaser set
There is much much more as it was difficult to determine from the debris whether or not something was stolen or incinerated - it's likely someone either has set up a small shop somewhere with the tools or will sell them individually to avoid suspicion. Please keep your ears/eyes out for anything that appears fishy.
Old Dec 23, 2010 | 10:44 PM
Tabris's Avatar
Holy cr@p. That is A LOT of things to take all at once. They must have had a frickin' moving van to pull that off.
I hope they get caught.
Old Dec 23, 2010 | 10:46 PM
Swivel's Avatar
Moderator
I'll definitely keep my eyes open. F'n scumbags.
Old Dec 23, 2010 | 11:09 PM
Hossmaxima's Avatar
That sucks man, karma is a bit*H and it will bite them in the ***.
Old Dec 23, 2010 | 11:12 PM
Project's Avatar
I would look at the next performance shop getting setup. I would have etched all those tools with a special marking or name. Damn that sucks hopefully insurance will pull through so hes not totally out.
Old Dec 24, 2010 | 12:12 AM
4DGS's Avatar
Yea, majority of my tools are burnt.
I really hope it all works out for him, that's a huge chunk of **** and even more hurtin' to burn the damn building down.
People are ****ed
Old Dec 24, 2010 | 12:26 AM
kennymo's Avatar
IF this is a true claim. i feel very sorry for him and i really hope he gets all his stuff back.
but...something is not right here. you would need a whole full size semi truck to get all that stuff out of there. and then to burn the place down? really?
im just sayin. insurance fraud is a bitch...and i hope thats not whats going on
Old Dec 24, 2010 | 01:17 AM
Frankieg35's Avatar
But he said he didn't have insurance.. Yeah they would need a big truck and a lot of time to pull this off.. And how didnt anyone see this going on??
Old Dec 24, 2010 | 01:41 AM
kennymo's Avatar
what major company doesnt have insurance? i really hope its not a scam on the owners part but i really think it is
Old Dec 24, 2010 | 02:03 AM
Sylvan lake V35's Avatar
Old Dec 24, 2010 | 03:21 AM
4DGS's Avatar
A friend of mine knows him well, unfortunately it isn't
Old Dec 25, 2010 | 05:33 PM
forweareLegion's Avatar
It's certainly one thing to steal tools and parts, but for the perps to have burned the shop to the ground. It makes you wonder.
Old Dec 25, 2010 | 05:35 PM
kennymo's Avatar
thats what through up a flag for me, well besides the huge amount of items that were taken.
Old Dec 26, 2010 | 12:31 PM
Eno's Avatar
Eno
Unfortunately nothing cleans up evidence quite like fire... I'm not close to the community but naturally I'll keep my ear to the ground. Like was mentioned earlier: Someone ALWAYS talks about it to somebody.
Old Dec 26, 2010 | 12:38 PM
1hotvq's Avatar
hmmm... 2jz motor swap cheap??...
j/k. ill keep my ears open as well. they should get caught cause thats alot of stuff. unless its all going on one car which there is no way.
