Wheel Fitment ??
Wheel Fitment ??
Hey Guys Just wanted Some Professional Help Here... I Have Been Searching For Weeks and Not Many People Here run 18x10... I Just Wanted to Know If This rim would Have Rubbing Issues or anything
Specs
2004 G35 Coupe Brembo Package
This Is For All 4 Corners
18x10
25 Offset
Fenders Rolled
Lowered on Tein S-Tech
No Spacers
I think im Going To Have Rubbing Issues...? Any Reccomendations of What I Can Do To Avoid This...Im Not Looking To Stretch The Tires By Much
Any Help Would Be Greatly Appreciated
Thank You,
Shoong
Specs
18x10
25 Offset
Fenders Rolled
No Spacers
Thank You,
Shoong
Close, the 265 would be pushing it in the front though for sure
245/40 or 255/40 if you can find them for the front
and 285/35 rear.
If you're rolled like you say you are you will actually be able to run spacers. If you're more willing to stretch, then you have more options and you'll be able to get a lot flusher. In that case though prepare to buy coils and get waaay lower.
and 285/35 rear.
Really there isn't. Especially with mild stretches. If you decide to slam the car and run camber then you are going to go through tires quicker but you don't NEED to run camber when you're low.
Other than that, tires are cheaper... which is great.
well now i got a set of 245/40/18's that would save me a bunch of money... but there yoko es100 i havent seen any stretched mostly bridgestones and falken 451's(im guessing 452's are the same)....but also looked up 245 on 10" and its stretched pretty hard...
I've never seen anyone stretch a 451. 452s however suck to stretch with. Yokos will be fine, besides you're barely going to stretch.
The only reason to use the 245 up front is actually so it doesn't handle terrible.
245/40 on a 10 is barely even a stretch at all.
I ran 225/35 on a 10 and still could have done more.
Alright Nice... im going to go for it then... im going to be running 245/40/18 All Around on 18x10 All Around... Any Suggestions On Spacers? Suspensions i MIGHT swap then for full coilovers but not right now... these are pretty good i like the drop...
Worry about the spacers after, if you're only on S-techs (about 1" right?) then you will be somewhat flush, could probably use a 5-10mm but once you get lower on coils then 20s or 25s might be more suitable.
Let me know when you get the wheels.
