Canada Serving Canada.
Any 1 tried this kijiji infiniti master mechanic..:)
Old Feb 22, 2011 | 08:39 PM
railer's Avatar
Was wondering if any 1 has feedback on this Kijiji infiniti master mechanic?
Seems promising.
On a side note, im looking to do the Drain-Refill exercise for the transmission fluid, just cant get a clear answer on which fluid to use.
I have a 06 G35C, the label says only use Nissan OEM J-Matic, but i have been told its not produced any more and if any 1 has it, its from a pretty old stock.
So can i just drain - refill with Nissan OEM S-matic instead (as in introducing 4 qarts of S-matic to go with the remaining 8-9 qarts of the J-matic) or do i have to take the old J-matic stock off the dealer (im sure he will be more than obliged)...?
has any 1 done this...?
Old Feb 22, 2011 | 08:52 PM
RBull's Avatar
Rated M
Only use the manufacturers recommended fluid.
Old Feb 22, 2011 | 09:06 PM
WhosRich's Avatar
Re-fill with Matic-S.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
