Canada Serving Canada.
anyone good with wood work?
Old Mar 30, 2011 | 01:51 AM
God|ZIlla168's Avatar
Just wanted to create a box to hose the amps etc in the trunk. Could anyone give me hand or help me make one?
Old Mar 30, 2011 | 02:02 AM
NMG-4's Avatar
best material you can use it's MDF 5/8 or 3/4 ,wood glue and some 16ga staples to put everything together.
Old Mar 30, 2011 | 06:55 AM
whatacar's Avatar
I wood, if I was closer. You might consider going into a Rona to their cutting area. Show them a drawing or just the measurements you want for the box and IIRC they will sell you the material and build it for you. Or you could have them cut the material and glue and nail it yourself.GL
Old Mar 30, 2011 | 07:13 AM
35bills's Avatar
Eric,
Are you keeping the "trunk" functional?
Where do you want the box mounted?
What kind of amp is going inside?
The amp will need space for heat dissipation for sure.
You could build a backing to mount onto the back to the rear seats and mount the amp there.
There are many options...
Old Mar 30, 2011 | 11:17 AM
GeeRider's Avatar
if your ggoing to be mounting to the seat, id say leave the box and just mount it straight on...
Old Mar 30, 2011 | 11:33 AM
BashaZ's Avatar
^^ I agree, Rona is pretty good when it comes down to cutting wood for free. It's also a lot less mess than doing it at your house
Old Mar 30, 2011 | 12:02 PM
redpearl99's Avatar
I use to be very good with woodworking, have most of the tools, but im way to busy to help
Old Mar 30, 2011 | 02:23 PM
Need a simple box to house a jl 500 amp and cross over box for the front speaker and a JL 300/2 amp
The box will replace the spare tire essentially. And I will need help to run the wire from battery to amp. Trying to do all these myself to save on cost.
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
