HELP !!!!! ... '06 Projector Retrofit on Canadian Coupe
Here's the link.
http://www.infinitipartsusa.com/part...layCatalogid=0
If you want a brand new set of projectors from an Infiniti dealership here in Toronto .... let me know ... I got mine dirt cheap since i am a part of their Infiniti club and hence the discount
Could you pm me a price thanks
until you get in an accident and someone sues the $hit out of you for not having DRLs....but it looks wicked
has anyone in calgary wired up projectors to have DRL to work. wanna make some extra cash and do mine. i have the headlights out so they can be worked of since i have 05 lights on right now.
i did a re wire which i have a pdf for. at first everything was working and now nothing does. so i ordered new wiring harness for the lights so if someone can take this on pm me
To fix the hyper blinking issues simply move the grounds before you install the lights, Also there doesn't seem to be an issue with burning out the high beam actuator due to the DRL sending power to it. I did a little webpage explaining what I done a few years ago, the headlights still working perfectly.
http://www.members.shaw.ca/wincana/G35CoupeLights.html
OP you are the man bro. I pulled out the smaller wire, and everything works fine. There was also a harsh click whenever i turned on the lights, which is also gone now.
as well, because of the stealth mode at night, ive decided to make a batman like apparatus and start fighting crime in brampton. so far ive apprehended a teen not wearing his hemlet on his bike. He paid dearly for his mistakes
Glad it worked out for you man ... and the batman idea sounds great ... haha ... crime in brampton comes to an end .. finally we got a superhero here ...
and no wonder i saw a flying bike rider the other day
I found a set of LED type fog lamps which fit into our bumper replacing the 2 wire mesh on each side .... will hook them up to the main power so that they are on at all times (again a simple hook up) ... it can work as DRL .... will keep you posted how it works out for me
Where do you live in Brampton?
Have you installed a plenum spacer on your G?
