Canada Serving Canada.
need some advice on a brake job
Old Jun 22, 2011 | 12:35 AM
railer's Avatar
I was due for a change, so picked up some centric blanks and stoptech street pads.
- in order to eliminate the infamous rust ring around the rotors, i decided to attempt to paint them with VHT HT Calipher paint.
Since im doing this for the first, i wasnt to sure if i should finish the job with clear coating it. What do you guys say, should i just put on the paint, let it cure and be done with it or should i apply the clear coat and if so when should i put it on (before or after curing the paint)..forgive me..im a noob wen it comes to painting
- I'm moving from Hawk hps to the stoptech street pads, however the pads i got didnt come with any anti-seize or grease compound. Im pretty sure i need to apply some anti-seize compound, so can any 1 recommend what to get from the regular auto stores (canadian tire, partsource or napa).
Also should i be getting anything else along with the anti-seize compound, like some copper based grease (i dont know just read it off 1 of the google searches)
thanks
Old Jun 23, 2011 | 12:14 AM
redpearl99's Avatar
dont worry about the clear coat, I just coat mine with black heat resistant paint
Old Jun 23, 2011 | 02:58 PM
forweareLegion's Avatar
All clear coat does on anything that sees high temperature is cause problems. Don't worry about it.
Freeman186
Sep 6, 2023 10:07 AM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
Joe Gargano
Sep 18, 2015 11:17 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
