Gas Guage not reading full...
Hey guys,
I seem to be having a problem with the fuel guage in my sedan. During the last two fillups( @ Sunoco) the guage doesn't read full. It sits about one notch below the full mark.
Has anyone ( esp in the Toronto area) had this problem?
I know there have been some posts in the past regarding this matter but my situation doesn't seem to be quite as bad as the others. Is it possible the sending unit in the tank is starting to malfunction?
Does anyone know of a possible cure( I don't want to make another trip to the dealer if I don't have to)?
Thanks for the help
35BILLS
Thanks for the help
35BILLS
Once your gas pump stop pumping into the gas tank, sometimes it not really full, it just stop pumping. You gonna have to twist the pump to 20-45 degree angle and then fill her up again... and then it'll be full. Try this and see what happens... other than that... take it to your dealership and have them check.
Originally Posted by 35bills
Hey guys,
Thanks for the help
35BILLS
Thanks for the help
35BILLS
Strangely, of late, it now goes right to the top again (when full). So whatever is causing the issue is intermittent.
I've read that our gas causes a problem with the gas sensors in the tank which in turn causes poor readings.
If it doesn't go back to normal, the dealer will have to replace the pickup, float, and sending unit apparatus in the tank. A common problem.
Another trip to the dealer UGGG.
Thanks guys for your insight!!!
I noticed this morning on my way in to work that the guage had moved up closer to the "full" level. I will keep my eye on this problem. Hopefully it resolves itself.
Cheers,
35BILLS
Cheers,
35BILLS
magnetism80
Jan 27, 2016 12:57 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Rhinos7777
Sep 6, 2015 05:36 PM
