Canada Serving Canada.
06 projector upgrade on 03 Coupe
Old May 5, 2012 | 06:08 PM
Ludeacris's Avatar
I am in the process of ugrading to projectors on my 03 coupe. I did the mod for the DRL however, only the drivers side light is working. I swapped the bulbs to make sure it wasn"t the bulb. I looked at connections and soldering, everything looks ok. I even check the old headlights to make sure it was the circuitry is fine on the car. Any ideas on what to try next to get the passenger side DRL ? Thanks
Old May 5, 2012 | 07:58 PM
JRollo's Avatar
Maybe a relay isn't functioning?
Old May 5, 2012 | 08:53 PM
Exceptional's Avatar
What's the difference between 06 and 03 projectors anyways?
i never found like a side by side picture
Old May 5, 2012 | 09:23 PM
Ano1te's Avatar
Old May 6, 2012 | 01:48 PM
Originally Posted by Ano1te
Did you register just to post that....
Old May 6, 2012 | 03:30 PM
Tabris's Avatar
The 03-05 use reflector based housings, the 06+ use projector based housings.
Old May 7, 2012 | 05:56 PM
Ano1te's Avatar
Wow your smart, yes i did bumpp
Old Jul 10, 2012 | 03:34 PM
Ludeacris's Avatar
Thanks for all the replies. JRollo, I did try other relays but still the same problem. I am going to swap the harnesses and see if somehow a problem with the harness. Will update accordingly.
Jusseth
Sep 13, 2020 12:25 PM
R350k5
Oct 1, 2015 08:41 PM
Kal Hamm
Jul 24, 2015 08:55 AM
