Canada Serving Canada.
Canadian NA Rev-Up Build
Old May 27, 2012 | 09:10 PM
The_Dr's Avatar
So awhile back I noticed engine was burning oil. I kind of expecting this since it was a revup and I knew it was bound to happen. I tired to put it off as long as i could. Until this past fall it was time to pull the trigger. this was not a easy task as there are not many machine shops in my area closest one was a 4 hour drive
Here is the problem related to the TSB for the rev up the oil ring ceases and it cant scrape the oil off the cylinder wall:
Pic 1
Pic 2
Here is the baby in question:
Pic 1
Pic 2
Picked up the motor last friday. Awsome work done by Gord Bush Performance
Pic 1
I initially was going to go with SG long tube headers but the problem is now i have to go for emissions test and I cant spend 9 hours swapping out the heads for standard ones with OEM cats to pass emission tests. So i decided at the last min to go Crawford headers. I also had some old Crawford cats laying around and i will cut out the old cat and put a resonator in.
I'm gonna stick with the rev up plenum for now. did some work on the upper plenum. I probably wont get any gains but it looks cleaner. Ideally I would love to get ITBs, but i cant justify the price. Or somehow mod a HR intake to let the engine breath more, but for now I don't know how to work around the MAF readings, but I'm sure ill find an answer out there since someone has already bypassed it for ITB setup. Also how to get multiple throttle bodies working together. Im sure the answer is out there just gotta dig deeper.
Wish I had more pics but the machine shop was too far away to get pics on progress.
Back home on the stand
Partially assembled
Closer..
Upper Plenum work
Car goes in the shop June 4th. Then the painful task of finding a tuner that's not hours away. But if i had to do it all over I'd drop in a HR and buy the harness adapter from Z fever, but its a little too late now oh well.
Build list:
Stock 2005 Factory airbox (revup) w/ high flow filter from K&N
Z-tube
MD 5/16th spacer
JWT C8R Camshafts
JWT Springs
JWT Clutch and fly wheel
Removed extra idler pulley
Ati Crank Pully
Crawford headers
Custom Test pipe with resonator
HR Y Pipe off an 2009 350Z
HR Head Gaskets
CP 96mm 11.5:1 Pistons .020mm overbore
Eagle H-beam rods
ARP Head Studs
ARP Main Stud kit
OEM Trust Washers
OEM Main Bearings
OEM Rod Bearings
Engine Gasket Kit
Ported Intake and Exhaust on heads
New oil and water pump
There is more but that's just the motor.
Old Dec 1, 2012 | 07:28 AM
North Van G's Avatar
Nice list of mods, what was the Dyno result from all that?
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
