Canada Serving Canada.
TPMS Sensor - can i buy online
Old Dec 18, 2018 | 10:14 AM
dandor268's Avatar
5 Year Member
Hi
Local place wants $350 for 4 sensors and install which seems a bit much.
I found 4 online ebay for $100.new.
Do these have to be programmed? Is it a bad idea using aftermarket TPMS sensors?
Thanks,
Dan
Old Dec 18, 2018 | 10:17 AM
Urbanengineer's Avatar
Hi Dan, yes the sensors have to be programmed. Dealer can do it for a fee or you can do it per the free method on the forum.
If you want a cheap alternative and brand new, aftermarket VDO makes TPMS sensors that are a great OEM style replacement.
Old Dec 18, 2018 | 02:13 PM
dandor268's Avatar
5 Year Member
Thanks for the quick reply!
How are universal brands? Like Autel
Is this the manual reset method you referred to:
1. Use a jumper to link the TPMS connector to ground (figure 2).
2. Key On Engine Off
3. Momentarily disconnect and plug back in the TPMS connector (5 to 6 times)
4. The TMPS warning light will blink when the system starts initiating.
5. Start the reset procedure with the left-front tire, then the right-front tire, then the right-rear tire, and end with the left-rear tire
6. Once the system has completed the reset procedure, the TPMS warning light on the dashboard will automatically stop flashing
Would i have to do this every time i swap the winter tires with summer tires (both sets with TPMS Sensor)
Old Dec 20, 2018 | 09:16 AM
Every season, as they are getting new sensors each season.
Not sure aboht Autel, I can confirm VDO works with flying colors.
