Canada Serving Canada.
Braided Brake Lines for your G
Old Apr 13, 2005 | 12:57 AM
duhprez's Avatar
Thumbs up Braided Brake Lines for your G
Just got my 48K service and had Jerry at Yorkville Infiniti install a set of braided brake lines complete with Motul full synthetic brake fluid.
With the set of brake lines on display, I couldn't resist. I didn't know what to expect, except that I've only read good things about getting braided lines.
After getting out on the road for a couple of hours and getting through a typical Toronto evening bumper to bumper rush hour, this mod is well worth the money.
It felt as if a new brake system was installed after noticing:
1. Much better overall braking response.
2. Much better brake pedal feedback.
3. More powerful braking effect requiring less pedal force effort.
4. Maximizes the potential of your brake system
5. Maintains braking performance consistency with continued use.
6. Brake pedel travel is reduced to achieve same braking effort compared with OEM lines.
In combination with Motul synthetic brake fluid, the Brembo's have really come to life. I highly recommend this mod whether your brakes are Brembo or non-Brembo. You'll definitely feel the difference and increase your braking confidence.
Thanks Jerry (jliu@dfcauto.com) for such a great job.
Old Apr 13, 2005 | 07:21 AM
35bills's Avatar
How much were the brake lines themselves and what manufacturer makes them?
Thanks,
Bill
Old Apr 13, 2005 | 08:24 AM
Balzz's Avatar
I had stainless steel braided lines in my old car and it made a significant difference in pedal feel. Putting in Motul fluid however doesn't make much of a difference in street driving and may actually be counter-productive since it's more hygroscopic than stock fluid. It may have a higher dry boiling point, but the wet boiling point is far lower than stock.
Old Apr 13, 2005 | 11:12 PM
smilepro's Avatar
Any thoughts or impressions of the motul engine oil? Was considering this for the next time I am in TO
Old Apr 14, 2005 | 01:23 PM
QRAFTWERKZ's Avatar
In real world terms DOT 5.1 synthetic fluid "DOES" make a difference as the fluids viscosity is 820 is lower than DOT 4 or 3, this allows for easier flow throught the braking system this means, quicker response, and more precise brake pedal feel, ask any G35 owner with BREMBO's with this fluid change.
And I am not sure where you got your information from BUT the fact also is that normal DOT 5.1 has a HIGHER wet boiling point 375F and the dry boiling point is also higher 518F, Motul DOT 5.1 has a wet boiling point of 356F, and a dry boiling point of 509F. DOT 5.1 brake fluid is also INHERENTLY MORE hydroscopic, its ability to hold moisture is much better than the lower DOT fluids , not to the rate of DOT 4 or DOT 3 which has lower boiling points, hence DOT 5.1 fluids requires less maintenance. DOT 5.1 brake fluid is a better choice for many racers yet some DOT 3 performance fluids can have as high as 675F boiling point. Hope this clarifys better.
...............Dry Boiling Point....Wet Boiling Point
DOT 3 .......... 401 F ................. 284 F
DOT 4 .......... 446 F ................. 311 F
DOT 5 .......... 500 F ................. 356 F
DOT 5.1 ....... 518 F ................. 375 F
Old Apr 14, 2005 | 01:45 PM
Balzz's Avatar
My mistake. Thx for the info.
Old Apr 14, 2005 | 02:04 PM
QRAFTWERKZ's Avatar
Thats not a problem I was SOOOO CONFUSED, I had to do my research myself too. I HAD TO KNOW!
Old Apr 14, 2005 | 02:49 PM
Balzz's Avatar
I actually wasn't aware of DOT 5.1. I was still thinking of silicone based DOT 5 but DOT 5.1 seems win-win to me.
Old Apr 14, 2005 | 04:15 PM
RBull's Avatar
Rated M
Thanks for the info Jerry. Is there any noticable benefit to going synthetic with the clutch fluid? If so what type?
Deane
jilljann1
Jul 21, 2020 08:12 AM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
NJ6MT
Sep 10, 2015 08:40 AM
