Canada Serving Canada.
Canadian A/T Coupe owners.
Old Nov 21, 2002 | 01:35 PM
Msedanman's Avatar
O.F. Administrator
Anyone in Canada with An A/T Coupe can they tell me if they got LSD or not (I've been told it comes with A/T as well as M/T)? Can you please confirm the tire sizes on the A/T coupe; from what I've read here they're FR: 225/45/18
RR: 245/45/18
Also what brands? Finding out info from my dealer is difficult at best and I appreciate help from you guys and gals. Around here there's not many Coupes yet and no brochures nor up to date web site . Makes it tough
Many thanks,
Gsedanman- Garnet Fire Sedan(till Jan/03)
Old Dec 1, 2002 | 11:56 AM
TripleQ's Avatar
Re: Canadian A/T Coupe owners.
Slip means VDC or TC is working, not LSD... LSD is a mechanical system.
Old Dec 1, 2002 | 01:33 PM
Msedanman's Avatar
O.F. Administrator
ablv009, in case you don't know: to check if your LSD is working you must first disable VDC. Then put one tire one ice or snow , the other on dry pavement. Now try to make it slip with very light throttle. Car should drive right out with no slipping. LSD transfers the power away from the slipping wheel to the non slipping wheel . Don't forget to reactivate VDC. Hope this helps. My D/G Coupe should be in soon.
Gsedanman- Garnet Fire Sedan.('till Jan.)
Old Dec 3, 2002 | 03:35 PM
Msedanman's Avatar
O.F. Administrator
According to the Coupe article in: www.thecarconnection.com the A/T in the new Coupe is slightly modified from the Sedan for better shifting. Can't wait.
Gsedanman-Garnet Fire Sedan('till Jan)
Hasanbaloch
Feb 29, 2024 08:45 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
multimut
Canada
Jul 26, 2015 08:43 PM
