Canada Serving Canada.
Thanks for all your opinions
Old Dec 6, 2005 | 12:01 AM
bikesbikes's Avatar
I just want to thank all of you that replied with your thoughts on my previous thread regarding the wheel I wanted to buy.
I decided to go with the Volk GT-V. They were the newer design so I figured I'd try them out.
Attached Thumbnails Thanks for all your opinions-image002.jpg   Thanks for all your opinions-image003.jpg
Old Dec 6, 2005 | 04:31 AM
Endless G's Avatar
Where are you getting them from?!??!
Old Dec 6, 2005 | 07:40 AM
M6_G's Avatar
and how much if you don't mind me asking... Looks for volks sf winnings myself..
Old Dec 6, 2005 | 10:05 AM
Msedanman's Avatar
O.F. Administrator
Nice choice man, they're not too different to my M wheels. Like 'em.
C.
Old Dec 6, 2005 | 04:52 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Excellent choice.
They'd be right at the top of my list.
You get the sizing sorted out?
face A, B or C & offsets
Old Dec 6, 2005 | 05:43 PM
Endless G's Avatar
I am so confuse about offset!!!!
What is the OEM spec
Can 350Z and 35 coupe wheels replace the one in sedan
Someone is selling its LE28N and it is so tempting!!!
Old Dec 6, 2005 | 06:40 PM
InTgr8r's Avatar
You've seen this B4, right?
Attached Thumbnails Thanks for all your opinions-sedan_wheel_fitment_chart.jpg
Old Dec 6, 2005 | 06:54 PM
Msedanman's Avatar
O.F. Administrator
Alan, The offset is no mystery bro, it's the difference between the centerline of the wheel compared to the similar line across the mating surface inside the wheel where it actually mates up to the hub, and is quoted in millimeters.
On our G's as in most rides, this offset is a positive one.
This number should be cast on the inside of each wheel as just a whole number without 'mm'.
In the owners manual you'll find the OEM specs for each ride in the wheel spec. chart., and from what I understand should be as close as possible when replacing wheels.
....So you need to check the wheels you want to use to replace the OEM's.
G/L and call if I can help any more.
Colin
Old Dec 7, 2005 | 06:03 PM
Endless G's Avatar
I think i have, but how do you look at it??!?!
Thanks for the info Colins, i ll be looking at them in Jan!!
Old Dec 7, 2005 | 08:05 PM
bikesbikes's Avatar
Excellent choice.
Thanks. I can't wait to get them on the car.
I got 19x9.5 +17 & 19x10.5 +24
I'm thinking of running 285's in the rear but I might have to roll my fender.
Old Dec 7, 2005 | 08:48 PM
Chico's Avatar
No they won't fit. The OEM spec is 18x7.5 +45 offset.
Old Dec 7, 2005 | 08:53 PM
Chico's Avatar
Not for anything bro...but that chart is inaccurate on the outside measurements. I have looked at it and compared and measured and it simply doesn't add up.
Point in case, my wheels are 20x8.5 +35. According to that chart I should be outside the fender line, but in fact I am 1/4" inside the lip of the fender in the rear and about 3/4" in the front.
The inside measurements are more accurate though.
Old Dec 7, 2005 | 08:54 PM
Chico's Avatar
Nice set up...where are getting them from?
Old Dec 7, 2005 | 09:06 PM
bikesbikes's Avatar
Believe it or not I got them from JRP.
I haven't done any measurements but I've been told that my setup it about the widest you "should" go. I've seen wider on show cars... but I don't know how good those setups would be on a daily drive.
I really wanted to go 20" but they were getting pretty heavy. Maybe when I'm pushing more power.
That's the next project.
Old Dec 7, 2005 | 09:10 PM
Endless G's Avatar
Those offset fits??!
Or they are for coupe?!?!?!
