Canada Serving Canada.
Re:Old Brake Pad Warranty Recall/Bulletin etc.
Old Jan 5, 2006 | 07:14 PM
RBull's Avatar
Rated M
Originally Posted by Burrcold
does anyone know if there is any warranty on the Brembo brake pads/rotors? I have an 04 and they have been making so much noise lately and aren't functioning nearly as well. My G has 25K on it.
If you require new parts there are much less expensive options than stealership. Check on aftermarket pads and Brembo rotors from a gdriver vendor or other supplier.
Old Jan 5, 2006 | 08:43 PM
Burrcold's Avatar
Absolutely. I will not pay the dealership prices for OEM parts. I work for a very large automotive supplier so I know how the "stealerships" work
Old Jan 5, 2006 | 10:16 PM
RBull's Avatar
Rated M
Glad you're totally up to speed and more.
Old Jan 6, 2006 | 10:25 AM
Msedanman's Avatar
O.F. Administrator
I agree.....why pay their prices.....
but they may be able to help with the sqealing, which a glazing of the pads to quiet them down for you.
Privided they're not worn out, that may be all they need.
G/L
C.
Old Jan 10, 2006 | 07:18 PM
G35CoupeToronto's Avatar
Brake pad/rotot replacement only applied to COUPES
Originally Posted by Calgary_G
The warranty is for the 03 & 04 only. A thing I did not like is that they machine the rotors rather than replace so you take some mm off them & down the road you will have to replace them now on your own tab....
Hi there,
U are mixing things up, the recall or service bulletin only applied to 03/04 coupes etc, not Sedans if course thats why your were machined. The symptoms/prob on Coupe are entirely diff than Sedan.
Old Jan 10, 2006 | 07:29 PM
2SAVVY's Avatar
Had my car in on Monday and they replaced all the pads on all four corners and replaced the rotors at the front but machined the rear rotors. How Infiniti gets paid is they have to send in the old parts to show the wear and if the rotors are not within spec after machining they have to replace as per dealer.
Hope that helps. Now is the '03/'04 Sedan also have that same warranty so I can let some friends know??
Old Jan 10, 2006 | 07:32 PM
BbyG35's Avatar
I have 2003.5 (May 2003) sedan and so far I've had two new sets of rotors in front, machined rear rotors and three sets of pads -- all under warranty. I'm at 59,000km and am now looking at other options.
BTW... As a sedan owner, I received the extended warranty letter from Infiniti Canada stating 60,000km or three years
Old Jan 10, 2006 | 09:33 PM
2SAVVY's Avatar
Now one of my friends is a second owner of his '03 G35 sedan but he is under 60,000 kms and he is sure it is under the 3 year mark. As a second owner is he still covered?
BbyG35,
Thanks for your reply. Looks like I will be going back again
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
NJ6MT
Sep 10, 2015 08:40 AM
3000vr4tt
Sep 7, 2015 12:48 AM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
johnadlertech
Interior
Sep 4, 2015 12:26 PM
