Canada Serving Canada.
Where do you guys purchase your maintenance parts...
Old Mar 26, 2006 | 10:23 AM
urabus's Avatar
Such things as:
- Differential oils
- MT oils
- Air filters
- Microcabin filters
Old Mar 26, 2006 | 11:37 AM
Balzz's Avatar
Filters - Stealership
MT oil - GM dealership, yes GM. Synchromesh Friction Modified oil rocks.
Old Mar 26, 2006 | 01:17 PM
RBull's Avatar
Rated M
Filter- mobil one -Everything G35 (parents transport from US)
MT- Lucas friction modified - CTC
Oil- Mobil One - Walmart
Diff- Quaker State - NAPA (may switch to Lucas)
Cabin- Gord's
Intake- K&N - CTC
In Halifax there are few options for products.
Old Mar 26, 2006 | 03:06 PM
Msedanman's Avatar
O.F. Administrator
- Differential oils -- CTC
- MT oils -- n/a to me, but I've read that the friction modified lube that Deane gets is good. I'm sure Deane does too, but I'd match the OEM viscocity and not go either thicker or thinner.
- Air filters -- either OEM (Dealer), or K&N (CTC)
- Microcabin filters -- Gord(gee)'s Hepa filters are much better than OEM.
C.
Old Mar 26, 2006 | 03:40 PM
RBull's Avatar
Rated M
- MT oils -- n/a to me, but I've read that the friction modified lube that Deane gets is good. I'm sure Deane does too, but I'd match the OEM viscocity and not go either thicker or thinner. - Air filters -- either OEM (Dealer), or K&N (CTC)
C.
On the gear lube I use 75W90 which is close to OE 75W85
Old Mar 26, 2006 | 03:51 PM
EEYORE's Avatar
Anyone use synthetics on the G35s? I was thinking of purchasing some Motul for the G, but I am unsure if its warrenty safe.
Karim.
Old Mar 26, 2006 | 04:02 PM
Balzz's Avatar
Wonder if it's the same stuff as the GM friction modified stuff. I know it's relabelled as different brands as well.
Old Mar 26, 2006 | 04:27 PM
Msedanman's Avatar
O.F. Administrator
Deane,
Should be fine.....what I meant was going way off the mark with visc.
BTW, I looked mine up to see that my M takes 80W90 in the diff :-- slightly thicker than for the G-cars. Still got some 75W85 on the shelf, but I guess I'll have to get some 80W90
As a point of interest, Q45Tech from F/A reckons that apart from keeping the gears 'happy', that quite a few ponies (5-10) can be had by keeping the rear diff filled with fresh lube. (thru friction reduction).
If it's true, that's not a bad little bonus for just changeing out that 2 liters.
He says to do it about every 15k miles.
FWIW...
C.
Old Mar 26, 2006 | 04:28 PM
RBull's Avatar
Rated M
Could very well be. The label says it has a synthesized additive and it is excellent for limited slip diffs. The auto manufacturers don't produce their own oils of course and would spec their stuff and then tender to lube co.
I like it. I first changed to Castrol syn. and it was terrible for notchiness in the MT so I immediately swapped it out for the Lucas. It seems to work great.
Old Mar 26, 2006 | 04:31 PM
RBull's Avatar
Rated M
FWIW...
I'm doing mine every 7.5 k kms
Old Mar 26, 2006 | 04:34 PM
Msedanman's Avatar
O.F. Administrator
Nice to know the Lucas works well in the G. I've heard a lot of complaints about that notchiness in the shifter after changeing out the lube.
Sounds like Lucas is the answer....
C.
Old Mar 26, 2006 | 04:37 PM
Msedanman's Avatar
O.F. Administrator
Better more often than not often enough, don't worry.
It's not that expensive and it's only 2-2.5 liters.
C.
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
Mac8008
Aug 4, 2015 09:19 PM
Terry_G35
Aug 4, 2015 02:38 PM
Frostbite91
Jul 27, 2015 05:25 AM
