Canada Serving Canada.
Shannonville Fabi Track day April 29th evening Saturday
Old Apr 19, 2006 | 09:33 AM
NismoSky's Avatar
Arrow Shannonville Fabi Track day April 29th evening Saturday
Hello all,
We have the track Saturday evening from 5:30 - 8:30 pm booked, cost will be $60 of prepaid for each participant. This event is opened for any cars, any models. And we have very tight lapping rules.
A little background -
The Fabi track at shannonville is probably one of the safest tracks you can learn on. It's not very fast (save for the 1/4 mile back straight) and very technical. It's also very fun and you'll spend the whole day mastering your line, and there are some pretty good photo ops.
I am limiting the track day to about 25 cars instead of 30s cars, so that it gives you plenty of room on the track while keeping the crowd down.
We will have a short briefing prior to getting out on the track, followed by a few warm up laps, then lapping for the rest of the day. "Lapping" refers to just that, doing laps. Passing is STRICTLY prohibited except on the back straight, and only when the person in front of you has allowed you by signaling you to pass. We reserve all rights to kick people off the track that are driving dangerously and/or aren't listening to track marshalls.
For those that have never been to the track, I encourage you to try it out, even if you're still on stock tires
All those interested in attending this track day on April 29th,
Kindly post and sign up in this thread. And email me your contact info.
Include first and last name, car type
i.e.
- My name is your name
- I drive: your car, model, & color
- I will drive my car at the track on April 29th.
Helmets are not mandatory, but you will have to sign a disclaimer at the track. (if you have helmets, it won't hurt to bring them up).
All those interested please sign up or email me asap. I want to build a list and collect prepaid track fee as soon as I can.
Prepaid: $60
After April 21st or At the track: $80
Pls signup for prepaid to reserve your spot asap and We don't accept anymore participants when all spots are filled.
** All prepaid no later than April 21st, Friday **
Please contact Kevin (416-5649999) if you want to meet up in GTA to pay for the track fee. Whoever wants to pay the track fee by , Email Transfer, Paypal or Money order please PM me for instruction.
feel free to PM/ask any questions..
* April 29th Shannonville Track lapping day's Meet Location & Departure details will be released on April 25th*
Old Apr 19, 2006 | 01:56 PM
Pete00's Avatar
What type of preparation is usually required for the track? Oil change before/after, brakes etc.? Thanks
Old Apr 19, 2006 | 02:23 PM
NismoSky's Avatar
make sure everything is in good condition.
not a must to have oil change before/after.. certain amount of brakepads should be enough for what you want to do on track, and how aggressive you want to do.
Old Apr 19, 2006 | 02:43 PM
Balzz's Avatar
Make sure you have fresh brake fluid, suspension in good shape, steering components in good shape, higher temp brakepads depending on the rubber.
Old Apr 19, 2006 | 03:50 PM
bigwilly's Avatar
Anyone want to do a step by step DIY with photos on how to bleed the brakes on the G? I've never done anything like this before. I'll be going to Shannonville on May 6th. It'll be my first time at the track. After which I would like to put in fresh fluid. I already have two bottles of Motul RBF600. What other tools are required?
Old Apr 19, 2006 | 04:17 PM
Balzz's Avatar
A couple of open wrenches (10mm for the front and 8mm for the rear I believe), and someone to work the pedals for you. Here's a copy and paste, but no pictures.
1.
Block a front wheel with a piece of wood to prevent the car from rolling. Raise the back of the car with a floor jack and then lower it onto a pair of jackstands.
2.
Remove the rear wheels.
3.
Open the brake fluid reservoir and remove as much old brake fluid as possible, using a suction tool or a turkey baster. Be careful not to spill any fluid, as it will dissolve the paint on your car.
4.
Fill the brake reservoir to the top with fresh fluid.
5.
Place a box end wrench over the bleed screw on the right rear caliper. Push a clear plastic tube over the nipple on the bleed screw and place the opposite end into a catch bottle. Auto parts stores sell nice catch bottles with a cover that prevents fluid from spilling if it tips over, a 1-way check valve in the cap, and a rubber fitting on the caliper end of the plastic line that snaps in place over a wide range of bleed screw nipple sizes.
6.
Tell your assistant to pump the brake pedal a few times until it becomes firm. This is especially important if you have just replaced pads. If you've installed new stainless braided brake lines or installed a big brake kit, there may be enough air in the system that the brake pedal will not get firm. That's OK. Just move on to the next step.
7.
Tap the caliper a few times with a rubber mallet or "dead-blow" hammer. This helps to knock loose air bubbles that may be clinging to inside surfaces of the caliper.
8.
Have your assistant PUSH hard on the brake pedal and HOLD. With a quick motion, open the bleed screw about 1/4 turn. Fluid (and probably a few air bubbles) will flow through the plastic tube and into the catch bottle. A light placed behind the tube will make it easier to see what is coming out of the caliper.
9.
Close the bleed screw just before the brake pedal reaches the floor. Don't worry if the timing is off at first. You will quickly figure it out with feedback from your assistant.
10.
Tell your assistant to RELEASE.
11.
Repeat steps 8 - 10. Do this about 6 times and then go to the front of the car to check the fluid level. You MUST NOT allow the level to fall to the point where you suck air into the master cylinder.
12.
Top off the brake fluid level and continue for a total of about 10 pumps or until you no longer see any air bubbles coming out of the caliper.
13.
Repeat the process for the other rear caliper.
14.
Make sure both calipers are wiped clean of brake fluid and that none has spilled on the rotors or pads. Use brake cleaning spray if necessary. Reinstall the rear wheels and torque to factory specification, then lower car to the ground.
15.
Now apply the parking brake, put the car in gear (or PARK) and raise the front of the car with your floor jack. Lower it onto a pair of jackstands.
16.
Remove the front wheels.
17.
Follow the exact same technique as with the rear wheels, starting with the passenger side caliper. The fluid will flow more rapidly out of the front calipers, so you will need to check the level in the brake fluid reservoir more frequently to avoid letting it drop too low.
18.
Reinstall and torque the front wheels, then lower the car to the ground.
19.
Top off the brake fluid reservoir and replace the cap.
Old Apr 19, 2006 | 04:31 PM
Jasonoff's Avatar
Humm.. never bled the brakes and you want to for the first time before a track event with expensive fluid.
Bad idea... I would get it done at a shop if I were you. It's hard to get a good bleed using the pedal and if you accidentally run the reservoir dry you'll have to purge the abs system.
Old Apr 19, 2006 | 04:53 PM
bigwilly's Avatar
Yeah I'll probably get it done at the dealer. I am scheduled for an oil change shortly after the track date anyway. I asked them last time I was there and they quoted something like $50 to bleed the brakes.
What about helmets? Do you need to get one for tracking and if so where to get a decent one without having to drop a lot of cash?
Old Apr 19, 2006 | 05:04 PM
Balzz's Avatar
Yes, absolutely get a helmet and use it even though some organizations don't require it. What do you consider a lot of cash?
Old Apr 19, 2006 | 05:22 PM
bigwilly's Avatar
What is a reasonable price. Some of the helmets that saw online where like $600-700 US, less would be good. Is that the going rate for a decent / nice helmet? I only know of Arai and Shoei, are there other brands that I should look into what is the difference between a helmet for a bike and for for your car?
Old Apr 19, 2006 | 05:35 PM
Balzz's Avatar
Well, I got my SA rated helmet for about 450 CAD from CSC Racing in Newmarket. http://www.cscracing.com/helmets.htm
Old Apr 23, 2006 | 07:57 AM
NismoSky's Avatar
if u are around GTA/Toronto, you can go to the "Cycle" bike store at McCowan on Sheppard Ave west. The starting price of some models of helmet "Shoei" are around $150 or above..
Old Apr 25, 2006 | 05:56 PM
NismoSky's Avatar
* April 29th Shannonville Track lapping day's Meet Location & Departure details*
Location :We will be meeting up in the plaza (Kennedy Common) at 401 and Kennedy. Kindly go into the plaza, look for the AMC Theatre and look for us. We will be meet at the parking lot in front of the AMC Theatre. I will be collecting money from those that haven't paid me.
Time: for meeting up in Kennedy Common (Kennedy & Hwy401) - between 2:00pm and 2:30pm
WE WILL BE LEAVING AT EXACTLY 2:30pm If traffic/weather is bad, plan that we will leave a bit earlier.
Regardless of whether or not you are coming up with the group or meeting us at the track, I will go over the track rules with everyone in the Drivers meeting at 5pm. Those that miss it, I will go over the track rules with U. I'm serious about this, as we want to be very clear that everyone knows what's expected of them, for everyone's safety.
We will MEET in front of the Gates/back of the Grandstand (Not in the Nelson track).
We will be allowed on the track around 5:30pm and will be lapping until the park closes at 9:00 at which point we will return to toronto.
Here are directions to shannonville.
From Toronto: Highway 401 east approx. 150 km (90 miles) to exit #556 - Shannonville Rd. Proceed south for 2.4 km (1 mile) to Hwy #2 - then east for 7 km (3 miles). Track entrance on the left hand side.
** Details and Maps are provided below **
we can exit #566, which is past the track, which is right next to a SUNOCO station, where you can refuel and get snacks
Old Apr 25, 2006 | 06:29 PM
godmans's Avatar
dude, why dun u organize one week later lol?
anyways, I am going to the one organized by Eric on May 6th
and btw, what's up with the Chinese; why dun you meet up in P-mall instead?
Old Apr 27, 2006 | 08:21 PM
NismoSky's Avatar
We have one on May 13th -> link
May 6th Saturday afternoon, we will host a big MEET with the drivers from TSC, Subarism, Lezus IS (my.is), Nissans Infiniti, drivers from jonjai.com, yorkbbs.ca, Maxbimmers, ...etc.
Time: 3pm
G35VSHNG37
Oct 25, 2015 08:43 PM
joel extreme
SOCAL Meetings & Events
Aug 7, 2015 03:09 AM
joel extreme
Jul 27, 2015 11:59 PM
joel extreme
Jul 23, 2015 04:13 AM
