Canada Serving Canada.
Anyone Installed an aftermarket LSD ??
Old May 15, 2006 | 02:59 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Hi guys....
I'm in the process of aquiring that components for a pumpkin swap.
Going to change my 3.3 fd open pumpkin for a 3.5 fd with a Quaife LSD.
Has anyone had this type of work done in the GTA?
Looking for a shop that knows what they're doing.
Any recommendations appreciated.
Old May 15, 2006 | 03:25 PM
SammyJL's Avatar
Ian is that viscous or a true posi (clutch type) LSD? If it is a posi then I'm jealous. I've been wanting one of those for more than a year now.
To answer your question though, I don't know of any shops off hand that do that kind of work but I'm sure they are out there. I don't imagine that the diffs are that much different than any other car.
Old May 15, 2006 | 03:37 PM
Balzz's Avatar
Quaife are torsen LSDs.
Old May 15, 2006 | 03:39 PM
InTgr8r's Avatar
Well...neither really.
It's helical gear driven, similar to Torsen.
Quaife LINK
Old May 15, 2006 | 04:48 PM
SammyJL's Avatar
That sounds awesome. Let me know how you like it after you get it installed. I want to know if it outperforms the stock VLSD in the coupe.
Old May 15, 2006 | 08:06 PM
RBull's Avatar
Rated M
Nice Ian.
Must mean the '04 will be in the family for a few more months.
Are there any other considerations with electronics/braking etc or are they non factors?
Deane
Old May 15, 2006 | 08:44 PM
InTgr8r's Avatar
Originally Posted by RBull
Nice Ian.
Yes it will..
I think I posted somewhere.... going to hang onto this baby.
Wasn't impressed enough with other products to do anything now.
There's going to be so much happening in the next 2 or 3 years,
I think I'll play in this sandbox a while longer
I also have a few other things in the works,
stay tuned could be interesting. ........ (no, not FI)
Deane
Pretty much a straight swap.
I found a 3.5 pumpkin out of a base 6MT 350Z.
They're an open diff. which works well for swapping in the Quaife unit.
I can do the re & re of the diff, but I need to find someone good to do the Quaife retrofit.
I've heard of guys swapping in aftermarket 3.9 final drive that loose cruise control.
No such issue with OEM 3.5.
Old May 15, 2006 | 09:09 PM
godmans's Avatar
you would still lose cruise control even with 3.53 FD.
at least from what I heard from people going from 3.3 to 3.5FD
Old May 15, 2006 | 09:12 PM
InTgr8r's Avatar
Not what I heard.
I know of one that didn't reinstall the sensor properly...
I guess I'll find out.
Either way I never use it anyway.
Old May 16, 2006 | 11:07 AM
Zat_Zuma's Avatar
Originally Posted by inTgr8r
Yes it will..
This is the same conclusion I arrived at when I considered selling my G35 coupe this spring. It's good to see that I'm not the only one thinking the same way, at this point in time.
We should compare "to do lists"
Old May 16, 2006 | 11:14 AM
InTgr8r's Avatar
LOL... I somehow don't think we'll be alone with this conclusion
Old May 16, 2006 | 11:17 AM
Chico's Avatar
Quaife LINK
Great find bro. What other parts are needed to complete the job? It looks very interesting.
Old May 16, 2006 | 02:10 PM
InTgr8r's Avatar
It's a direct retrofit for any open diff, w/o vlsd.
Can also be done on a vlsd diff, but requires new stub axles.
They recommend installing new side bearings,
since they can be damaged removing them from the OEM diff.
Other than that, it's labour.
I'll do the pumpkin re & re myself;
just need to get someone to install the Quaife in the pumpkin.
Old May 16, 2006 | 09:34 PM
RBull's Avatar
Rated M
Yes it will..
you've done the testing and research so I'm inclined to believe you on the competition. That is pretty much my impression too with what I've been reading.
The diff change should be a neat noticeable change both performance and traction wise.
My vlsd works somewhat. The right wheel seems to spin more easily though on harder launches.
I'll be watching closely for your other mod......
Old May 16, 2006 | 09:37 PM
InTgr8r's Avatar
other(s)
