04 screen swap
04 screen swap
I'm looking at doing a carputer install, and was wondering if there was a way to switch between the carputer and the stock navi/vehicle info feed for the touch screen. I ask this since I would like to be able to view the vehicle info screen and navi when I choose.
I've seen info on the converter for the stock screen, but not really any info on the touch screen to stock conversion. Any help would be appreciated!
I'm doing something similar. I'm using a beaglebone black running android JB and I'm going to output it to the factory screen (which Ive replaced with the OEM nissan 7" touchscreen), Ill be able to switch back and fourth from android/stock with a touch of the corner of the screen.
to answer your question though, there are some interfaces out that would allow you to do what you're looking for, here's one:
http://tvandnav2go.com/home/74-nissa...interface.html
I am looking at replacing my factory screen as well, can you please share more info on your nissan touch screen?
What are your thoughts on using small tablet in the motorized housing instead?
[QUOTE=marteb73;6771879]I'm doing something similar. I'm using a beaglebone black running android JB and I'm going to output it to the factory screen (which Ive replaced with the OEM nissan 7" touchscreen), Ill be able to switch back and fourth from android/stock with a touch of the corner of the screen.
either way works, a tablet is a great alternative due to the high res screen and great touch response (better than most fact screens), provided you're comfortable adjusting/molding the dashboard and making it work.
A buddy of mine is developing a piece that allows you to control any tablet's volume and track buttons through the factory steering wheel controls...with the anticipation that people will be mounting tablets in their dashboards more often in the coming years.
You planning to use straight AUX input for audio?
The screen I'm using is not the same as the motorized pop-up in the G35s, i believe that one is different (but i could be wrong, someone I hope can confirm). this screen was from newer G's/M's/Pathfinder/Murano etc.. the whole assembly is a bit thicker
Yes was planing on using the aux input from my PAC interface either directly or through airplay by installing an airport express somewhere under the dash
What year is your G? Are u able to pop the screen up and down without obstruction ?
That's a clever idea, your buddies piece, if worked correctly would make using a tablet even more of an elegant solution
Car computers were all the rage 2000-2010 because aftermarket stereos offered little to nothing modern ones do.
Now that we have fancy touchscreens and such, we don't need car computers anymore, money is wasted on them.
But a steering wheel control to bluetooth remote controls would still be handy for both.
