Argh.Side Molding Damage.Any Suggestions.See pic
Hello.....quick story.....apparently my father was bouncing tennis ***** to my 5 year old son who was trying to hit them with a tennis racquet and one bounced into the side of my car.
Apparently at the right angle to cause damage to the plastic strip on the door (see pic).
Are there any products out there to change the stressed (white) plastic back to black. I tried car polish and wax and scratch remover with no luck as expected. Does anyone know if there is a product out there to fix this or do I need to replace the plastic molding? Thanks in advance.
<a href="http://photobucket.com" target="_blank"><img src="http://i14.photobucket.com/albums/a317/budzync/8b86e430.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
Are there any products out there to change the stressed (white) plastic back to black. I tried car polish and wax and scratch remover with no luck as expected. Does anyone know if there is a product out there to fix this or do I need to replace the plastic molding? Thanks in advance.<a href="http://photobucket.com" target="_blank"><img src="http://i14.photobucket.com/albums/a317/budzync/8b86e430.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
Someone else may have an idea, but as far as I can tell once the plastic is deformed like that there is no going back. I'd guess you'll need to replace them. Bummer really, it'd almost have been better had the ball hit your paint.
Thanks for the response. I figured replacing it would be the most likely option. $50 for the piece, now to search for installation tips as I have the sedan so i hear it clips into the door.
I wish the ball would have hit the paint also......just not too hard :/ It is not as noticable as long as i do not park on a black surface, but my parents driveway is blacktop, so I saw it as soon as I came out of their garage
I was hoping that there might be a black tinted polish/wax out there that might help.
Good luck.
Originally Posted by Tweaksalot
i think its a sign from God telling you to remove the side moldings all together from your car
FS[NorEast]: New OEM G35x Compression Rods - Save!!
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
