window washer fluid
Old Jun 12, 2006 | 03:27 AM
WaLLy's Avatar
Originally Posted by smokedhen
seems like a stupid question, but I'll liked to know. does it even matter what window washer fluid I put in? I think they have some at autozone for a buck.
thanks
doesn't your dealership fill it back up whenever you get your oil change done?
Old Jun 12, 2006 | 06:03 PM
Mr. Wonderful's Avatar
They are pretty much all the same, so it doesn't matter.
Old Jun 18, 2006 | 07:14 AM
SURFJ9009's Avatar
Use any of them. They are all the same,
I dilute mine with about 1/2 water. Lasts longer and is easier on the paint.
Plus I use it often.
Old Jun 18, 2006 | 04:25 PM
jimNC's Avatar
Only time it could possibly matter is if you lived somewhere very cold, and it was winter. Other than that, use anything you want.
Old Jun 18, 2006 | 07:18 PM
G35stilez's Avatar
Concours d'Elegance
You could be really **** and empty the reservoir (via holding down the lever in the cabin) and fill it with:
-1 topful of 1Z Kristallklar Premium (http://www.drivewerks.com/catalog/sh...inszt_pg12.htm)
-The rest with distilled water
It works much better on dirt, bugs, and grime, yet is still safe on your finish (wax/sealant).
In any event, most of the other stuff purchased in the stores, is the same.
Old Jun 19, 2006 | 05:49 AM
DHCrocks's Avatar
second the distilled water...that way it doesn't leave water spots when you use it. just run the thing dry and fill in a gallon of distlled water. I also use a little bit of the rain-X washer fluid additive.
Dallsinghjr1
Sep 17, 2023 11:25 AM
f22raptor
Mar 18, 2016 08:50 AM
BradMD_96
Oct 6, 2015 09:31 AM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
