how to get rid of watermark stains on the hood?
Old Jun 25, 2006 | 01:49 PM
nyckid's Avatar
i recently washed my car a few days ago,and the next morning i noticed that i have watermarks on the edge of my hood when i come up close to it. Its a black coupe...
i try applying water and rubbing with a mf cloth, and it still there... anyone know what i can use to remove these stubborn waterspots w/o ruining my paint!
I waxed my car about 3-4 months ago, and im guessing these waterspots are under the layer of wax. I can be wrong tho.
I also heard that applying waxing to the area might help get rid of the waterspots also, is this true?
Old Jun 25, 2006 | 02:02 PM
gary c's Avatar
Hardwater stains.......ouch!
To be safe, I would take your car to a good detail
shop and let them do it! If the waterspots are really
bad it may have to be colorsanded....ya know baked
on. This happned to me last summer but I caught
it within half an hour......rushed home and stripped
the hood and then reapplied my wax......LOL
Old Jun 25, 2006 | 07:16 PM
G35stilez's Avatar
Concours d'Elegance
Did it rain that night?
Did you wash it any differently?
Unless you used a sealant like Zaino, there is no wax on there anymore.
PM me if you'd like...I detail on the side in the 5-boroughs, CT, and LI.
Old Jun 25, 2006 | 07:21 PM
FLAG35's Avatar
tossed salad anyone?
if the water mark is from "hard water" drying on the surface, a 50/50 water:vinegar mixture works like a charm. wet the car like you were gonna wash it, then wipe with the mixture on a sponge and leave for 10-15 seconds then wash off with water.
Old Jun 26, 2006 | 02:53 AM
Gpair's Avatar
Will that work on glass? My side mirrors have some hard water spots on them.
Old Jun 26, 2006 | 05:16 AM
DHCrocks's Avatar
I had a bad water spotting problem on my whole car from sprinklers once, I tried washing, quick detailer, cleaner wax, maguires step 1 cleaner, nothing worked. I finally resorted to a claybar (4 long hours) and that got most of it off but some stuborn stuff was left, after that I used maguries scratch-X and that worked great. I say skip the preliminaries and go stright with scratch-X
Old Jun 26, 2006 | 11:49 AM
g35john's Avatar
I had a similar problem and the only thing that worked for me was to get a wet rag and let it sit on the water spots and dissolve the depossits. I didnt try the vinigar though.
Old Jun 26, 2006 | 12:07 PM
dream_G35's Avatar
+1.......?
Old Jun 26, 2006 | 10:25 PM
nyckid's Avatar
so 50/50 on vinegar+bottled water will do the trick? Well what it was is that the waterspots on my hood have been on there for about a lil over a month or so, it was from these damn sprinklers that i came across one night when i drove home. My car has been garaged ever since that though. So will this solution work still?
Or should i try to clay that part? Not sure which would work better... The vinegar thing wont ruin my paint right?
Old Jun 26, 2006 | 10:52 PM
Picus's Avatar
Staff ALUMNI
Vinegar won't ruin paint. It works the same way alcohol and water does. You can also try Klasse All-in-one by hand or with a PC, that almost always cleans up hard water spots.
Old Aug 20, 2006 | 10:26 AM
filanj's Avatar
sideview mirror wear...
Originally Posted by dream_G35
+1.......?
for u guys with problems with your sideview mirrors, check out my thread...
https://g35driver.com/forums/interior-exterior/108178-side-view-mirror-wear.html
Old Aug 20, 2006 | 10:28 AM
filanj's Avatar
FLITZ metal and paint polisher is the answer
Old Aug 20, 2006 | 10:33 AM
Picus's Avatar
Staff ALUMNI
Any abrasive polish will remove calcium deposits, since it's also abrading paint. I'd suggest a chemical cleaner for future use so you're not using an abrasive over and over to remove water spots.
Old Aug 20, 2006 | 12:34 PM
LMG_35C's Avatar
..I'd try the white vinegar (50%) / water, or better yet Isoprophyl Alchohol (30%) and water before using any abravsive. Use demineralized water for either mixture. Give it some time (~5min) to neutralize the calcium but not too long and not out in the sun - be sure the surface is cool before you begin. Search Autopia.org for this solution.
After you see the deposits gone, wash, polish & then wax.
Good luck.
Picture Share
Feb 4, 2018 12:41 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
hrdwirk1
Oct 2, 2015 06:34 PM
