Menzerna FPII + s100 pics
on
Originally Posted by 35bills
What kind of pads are you using?
Maybe your not using a pad thats not aggressive enough. It would take much longer to acheive the results your looking for using finer pads.![Frown](https://g35driver.com/forums/images/smilies/frown.gif)
on
rotary usually goes quicker than a DA if you know how to use it. Plus you only did a 1 step polish while he was trying to do 3. Depending on experience it could take up to 10 hours
thats a 2 step polish + full metal jacket which btw it seems its easy on/off, still even if i did the FMJ by hand i dont think it would have taken me 10 hrs just for polish + FMJ or wax, maybe doing a full (inside/outside/wheel wells/taking off rims/engine bay/carpets/) detail i see myself spending 10 hours on my car, but thats just me...
Originally Posted by driguez
10 hours?
it took me about 2 hours to polish the entire car
![EEK!](https://g35driver.com/forums/images/smilies/eek.gif)
I use this constant pressure power pad with the Menzerna Intensive Polish: http://www.properautocare.com/coprorpopa.html
Then I use a standard white polishing pad with the FPII. Then FMJ is applied. Afterwards, when I inspect the surface under the sun, I don't see any swirls or scratches.
Given that the detail job and pads stay exactly the same, and you use a porter cable 7424 instead of a circular polisher, about how much longer would it take using the porter cable?
on
Originally Posted by chiapet15
Are there any swirls in the paint when you look at it in direct sunlight?
im not a pro by no means, im still learning, i know that G35stilez and picus are knowledgeable guys when it comes to detailing so oyu might wanna ask them...before the mezerna + finishing pad (lake country) i did have swirls, that was the reason i got the menzerna and pad, but now i have no swirls what so ever.
to be honest i couldnt tell you how long it would take me with a PC bc i dont own one. if that process is working for you then it works for you!! thats all it matters, whether it takes 10 hours or 1 hour
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
Concours d'Elegance
on
With the user being proficient with the rotary and PC, the PC will take about 1.5 times longer than the rotary.
FS[NorEast]: New OEM G35x Compression Rods - Save!!
The Fixer
Steering & Suspension
11-01-2015 03:26 PM
