bad idea??
Old Sep 24, 2006 | 06:05 PM
aszatk01's Avatar
bad idea??
hey guys, need a recommendation.
claybar'd last weekend so i want to get my zaino applied asap while the paint is as clean as possible. problem is i might be borrowing a porter cable to help with some swirls/scratches....i dont know when i will be able to borrow/ get a chance to use it soon.
so would it be ok to just do my standard procedure with zaino then if and when use the pc to remove swirls???
or is it not a good idea to use the pc for swirls/scratches after a freshly zaino'd car?
if it is ok to do this--would you recommend a final coat of z2 after pc'ing the car?
thanks in advance
Old Sep 24, 2006 | 07:48 PM
GTScott's Avatar
I would definitely use the PC for scratch removal if you think you are capable. Some reading on autopia.org may also help with this. Generally, for swirl removal, I would use a rotary but if you are not familiar with that you could do some real damage. the PC i smuch more user friendly.
the polish step will remove your sealant and thus you should seal again following the polish. Also, I am a big fan of wiping the car down with a 50/50 alcohol/water mix following polishing and prior to Zaino to remove any silicon or oils that the polish may leave.
-GT
Old Sep 24, 2006 | 07:50 PM
nm3th's Avatar
When you use a pc, you're removing the zaino along with the scratches/swirls. So you'll have to reapply the zaino after you use the pc.
Old Sep 24, 2006 | 09:05 PM
aszatk01's Avatar
k thanks guys....figured that might be the case
so i'll either do it by hand first or just wait for the pc.
Old Sep 24, 2006 | 09:08 PM
2006_G_coupe's Avatar
Just do it all at once.!!
Old Sep 24, 2006 | 10:24 PM
aszatk01's Avatar
^^well duh! i'd love to--thing is i wanna do this asap and i dont know if i will be able to borrow the pc anytime soon.
champppy
Mar 31, 2020 12:25 PM
Tylerttn
Aug 10, 2015 07:13 AM
will091195
Jul 27, 2015 09:19 PM
ddietz97
Jul 26, 2015 06:16 PM
