Removing swirls?
Old Nov 27, 2006 | 12:11 AM
scorpion246's Avatar
Removing swirls?
Hey guys I was wondering how to, or if possible to remove swirls on my G 05. if they do go away will they come back? Should I just go to a professional detailer? Any suggestions would be great. If anyone knows of a local good detailer(pomona, diamond bar, west covina all in ca) that would be great Thanks.
Old Nov 27, 2006 | 04:57 AM
cungkpham's Avatar
theres a detailed section in the DIY.
Old Nov 27, 2006 | 11:37 AM
twitch's Avatar
Yes it is possible to remove swirls from the paint.
In your situation it may be best to have a pro do it for you since you don't have any tools to get the job done correctly.
I suggest having it detailed professionally then changing your washing habits/techniques to reduce wash induced swirling.
Old Nov 27, 2006 | 11:38 AM
CERTAUTOG35's Avatar
With a PC and the right products you can remove the swirls in 5-6hrs probably depending how bad they are
Old Nov 27, 2006 | 11:44 AM
exceldetail's Avatar
Small car, I would hope even less then 3 hrs...........
Old Nov 27, 2006 | 12:03 PM
ac419's Avatar
in another thread people were using the zaino pc or (zpc) found here http://www.zainostore.com/Merchant2/...ory_Code=Zaino. from what people have been saying this product does wonders i'm gonna get some myself although i dont have any swirls yet
you may want to change to some microfiber towels to reduce the chances of scratching
Old Nov 27, 2006 | 01:10 PM
Thanks.
Thanks for the tips guy's, I made a few calls and one shop said they wanted $275 to $300. Its tough to tell which one's good and which one's over priced.
Old Nov 27, 2006 | 10:08 PM
Excel you are definetly right that it can be done much faster i went off the assumption that he was a newb
Old Nov 27, 2006 | 10:09 PM
AC Zaino will not cover any swirls it will actually bring them out you need to have almost perfect paint to put that on to make it look amazing
Old Nov 27, 2006 | 10:37 PM
Paragon's Avatar
AC was referring to the Zaino Paint Cleanser / Swirl Remover product, which is an abrasive. It had some good reviews on Autopia.org from what I recall.
Old Dec 3, 2006 | 07:47 PM
Eticketride's Avatar
What about zaino z-5? It is not an abraisive and it will hide the swirls. Can anyone tell me how well this hides the swirls? Or is it a waste of time and one should go directly to the abraisive (z-pc)?
Old Dec 3, 2006 | 11:52 PM
Picus's Avatar
Staff ALUMNI
It's like it's not even there! :/
https://g35driver.com/forums/showpos...59&postcount=2
(FWIW, Z5pro hides very light swirls reasonably well; it is a good alternative to polishing)
Old Dec 4, 2006 | 11:01 AM
RBull's Avatar
Rated M
I think I understand what you're saying.
Old Dec 8, 2006 | 11:21 AM
Can you use z-pc on the bumpers and on the headlights?
Old Dec 8, 2006 | 11:48 AM
Picus's Avatar
Staff ALUMNI
Yes, and yes.
