Cleaning spray on wheeel
Old Dec 8, 2006 | 01:03 PM
Sidewy8's Avatar
Does anyone use products like these to clean your wheels?
http://www.eagleone.com/pages/produc...=1003&cat=5006
Old Dec 8, 2006 | 01:27 PM
Calvin's Avatar
Overglorified Altima
stock wheels?
if you wanna use this on volks, works, etc. then i wouldnt suggest it. ive been told many times that soap and water is the only way to go.
Old Dec 8, 2006 | 01:31 PM
brianmfournier's Avatar
Stock wheels maybe but you have to be careful b/c they all contain acidic products and can ruin the clear coat or paint on the wheels
Old Dec 8, 2006 | 05:06 PM
kenchan's Avatar
i only use car shampoo but you can try Griot's WheelCleaner which is
approved by BBS.
www.griotsgarage.com
Old Dec 8, 2006 | 05:31 PM
exceldetail's Avatar
Eagle ones Wheel cleaner is perfectly suited for todays wheels, and also recommended by many manufacturers. Its also acid free, as most OTC wheel cleaning products are. Try not to use on warm wheels, or in direct sunlight. Product drying is your enemy. Pre-wet wheels, spray product, agitate with a soft brush and you'll be fine. Rinse thoroughly, then seal with a Polymer spray product to deter brake linings from adhering.
Old Dec 8, 2006 | 05:36 PM
izmir41500's Avatar
G35driver Addict
i use that stuff to pre-clean. gets a lot of brake dust off. then i go back with soap and water,
Old Dec 13, 2006 | 05:49 PM
Chrlesmd's Avatar
I use it on my stock wheels. Seems to do a decent job breaking up some of the brake dust. I've tried the Dupont Teflon wheel cleaner too. I think the Eagleone is better.
Old Jan 6, 2007 | 05:12 PM
2K6G35's Avatar
DO NOT USE IT IN A HOT DAY!!!
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Duffy25
Accessories
Oct 12, 2015 01:45 AM
dcsbh1
Oct 1, 2015 03:15 PM
