silly question about Coupe tinting
Old Nov 14, 2003 | 08:52 AM
TINMAN's Avatar
about window tinting.i know when you apply the film on, the door need to be open.but on the coupe,when the door open,it's drop down half an inch.how did you do it? or do you know how did your installer do it?
<P ID="edit"><FONT class="small"><EM>Edited by gsedanman on 11/14/03 07:00 AM.</EM></FONT></P>
Old Nov 14, 2003 | 08:59 AM
Chops1's Avatar
Re: silly question
You can tape the button on the door which will keep the window up, but make sure the door dosen't get shut in the up position.
chops's Avatar
Re: silly question
Old Nov 14, 2003 | 09:38 AM
Mooser's Avatar
Re: silly question
I think it would something as simple as disconnecting your battery.
2003-G35C-5AT Laser Red/Black/Prem/SAT/Tint/Chrome 17's/Black Badged
Old Nov 14, 2003 | 09:43 AM
TINMAN's Avatar
Re: silly question
i like CHOPS idea.when i push that button with my finger,the window rolls up without the door being shut.
Old Nov 14, 2003 | 09:59 AM
Msedanman's Avatar
O.F. Administrator
Re: silly question
I don't think the window will 'seat' itself and go right to the top until the door is closed. So opening the door and lifting the window up won't fully close it.
The only way I can think of is to close and seat both windows, and b4 either door is opened, have someone disconnect the battery so that neither window goes down that quarter inch.
I'm sure the doors open ok that way so that the tinting can be done, then b4 the doors are closed at all, the battery will have to be reconnected to bring the windows down away from the seated position. **This is just a guess**
Perhaps someone has watched the tinting shop do this????
GSM
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Old Nov 14, 2003 | 10:25 AM
TINMAN's Avatar
Re: silly question
when i press on that button,the window did FULLY EXTENDED up.so no need to disconnect the battery.remember disconnect battery WILL reset alot of things
Old Nov 14, 2003 | 10:47 AM
Meatshackle's Avatar
Deep Sea Moderator
Re: silly question about Coupe tinting
Don't disconnect the battery with the windows up!
All it takes is one person to forget and close the door and you're out a lot of money. Taping the button will extend the window. My installer just pressed the button when he was working on the lower edge.
Russ
Black w/willow, 6MT Coupe, nav, aero, V1, PS2, & TVs all up in the headrests.
Jax, FL
Old Nov 14, 2003 | 12:08 PM
Geedup's Avatar
When I had my tint installed they disconnected the battery.
6MT
Omi's Avatar
Omi
Charter Monkey Florida G35 club
From: on some Prius forum somewhere. Also getting 60mpg.
you can take the screws out on the doorsill buttons for the windows and that way the ground is broken and the window stays up; just make sure they put them back in before shutting the door or the window will break
Old Nov 14, 2003 | 12:57 PM
fayzter's Avatar
my guy remove the entire door panel to tint the front windows.
Old Nov 14, 2003 | 01:13 PM
stevedg35's Avatar
i have no idea what the guy did to mine.. i wondered teh same as you how he would do it. but i know he never popped the hood to disconnect battery.. he never popped the door trim off.. but when it was done and the doors were shut it was perfect.. so dunno? most of the time they offer a lifetime guarantee.. at least mine did so i figured whatever.. if it ends up being 2" short on the bottom i just have them redo it...
Old Nov 14, 2003 | 01:21 PM
surewin's Avatar
My tint installer removed the screws as well to the rubber button which disconnects the screw as well which disconnects the ground, causing the windows to roll up.
Old Nov 14, 2003 | 05:02 PM
PinoyG35's Avatar
my installer used a rubber-tipped clamp to keep the window up.
Using tape is not the first option since it might come off, especially since water is needed to install. You wouldn't want the window to jerk when you're not prepared for it!!!
Old Nov 14, 2003 | 07:38 PM
Sting_G35Coupe's Avatar
Listen to Omi...
If you simply remove the silver screw in the door jam, the one next to the button that triggers the window and interior lights, then the window will stay up. Again, be very carefull to not try and close the door with the windows up, can be very costly.
Good Luck...
G35 Coupe | Twilight Blue | 6MT
View Car Pics at: http://members.cardomain.com/sting_nc_g35
