Car cleaning
Old Jan 21, 2007 | 09:21 PM
dubbletrubble's Avatar
Kevin (picus112) would be the one to talk to, he is the detailing god.
A great website to look at would be www.autopia.org as well, it will have everything you need to know.
Old Jan 21, 2007 | 10:23 PM
Picus's Avatar
Staff ALUMNI
https://g35driver.com/forums/repairing-detailing-diy/105461-detailing-caring-your-ride.html
Old Jan 21, 2007 | 10:27 PM
Garnet Canuck's Avatar
Traveling Administrator
+1, Kevin is definitely THE GUY to talk to about this. Check out his thread below.
https://g35driver.com/forums/showthread.php?t=105461
What kind of polish did you use? It would have to be an abrasive polish in order for it to remove any swirl marks. A very thin layer of your clearcoast will need to be removed, and that's where your abrasive polish and a Porter Cable come in. I use Poorboys SR2.5 and SR2 with my Porter Cable (which was a recommendation from Kevin). Good luck.
EDIT: I see Kevin already responded!
Old Jan 21, 2007 | 10:43 PM
kenchan's Avatar
im running Griot's Polish1 to 3 and on new cars that's about as aggressive
you need to go unless it's more like a scratch than a swirl.
you probably didn't work the swirl remover into the paint long enough.
even on a moderately swirled paint, with the orbital, it usually takes me
about 3min to do a 15x15" area. then redo it over with a finer polish
another 3min or so....so by hand, it would take me more like 15+ min
in the same area using moderate pressure.
if by hand, try some ScratchX give a good 4-5 apps with some elbow grease
and see how much swirl you can remove. you might want to get that
initial coating you got off with some Griot's PaintPrep.
Old Jan 22, 2007 | 09:27 AM
35bills's Avatar
A Porter Cable 7424 is a random orbital polisher. It will not cause harm to your cars surface due to the way it rotates and spins.
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
johnjohn077
Brakes
Aug 4, 2015 01:37 AM
newg37
Jul 26, 2015 09:32 AM
vstypicals
Jul 20, 2015 10:55 PM
