cleaning the inside of the g? help
Old Feb 7, 2007 | 04:07 PM
06g35coupe's Avatar
i have an 06 coupe and have noticed that the metal trim inside has small scratches and i wana know if there is a product that i can use to polish this and take the scratches off? any help would be great! thanks everyone!!
Old Feb 7, 2007 | 04:16 PM
06g35coupe's Avatar
bump
Old Feb 7, 2007 | 05:54 PM
GR8TG35's Avatar
If its the aluminum trim pcs......I would leave it alone....
if you try to polish it, it will only remove the texture/satin look, and make it shiny in that area..... Or you could try using a light polishing compound....but be real careful not to over do it....
I have had some success using a med. grit steel wool, and go over the scratched area in the same direction as the finish.....it sometimes will blend in the area nicely.
DO THESE AT YOUR OWN RISK!!!!!
Just my $.02
Good luck
Old Feb 7, 2007 | 06:00 PM
gary c's Avatar
Trim cleaning......scratch removal.........!
Other than wax I would leave it alone!! Chances are you'll only make it
worse than it is. On my last two cars my wife has scratched the passanger
window with her rings.......live with it......what can you do?
Old Feb 11, 2007 | 01:14 AM
06g35coupe's Avatar
thanks for the advice. everybody
Freeman186
Sep 6, 2023 10:07 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
