Thin Zaino coats
Thin Zaino coats
One caution I keep on reading about re Zaino products is not to over apply - ie one ounce does the whole car - my question is, how?
My old-school thinking imagines one ounce getting absorbed right into the applicator before I even get started!
How does one apply such a thin coat, especially from bottled (versus trigger spray) products?
The secret with all sealant products is a thin application. I have been using Z2p/Z5p for quite awhile. I can get about 3 coats from about 15cc's in a 30cc syringe. That's right, I use a 30 cc medical syringe that looks like this:
I pour the Z2p or Z5p into the top of the syringe. I make sure the end is plugged with a small nail. I mix with ZFX if I need it. Squirt a couple shots of Z8. I then mix it all up and reinsert the plunger. The syringe method is much better for applying those thin layers of product onto a terry cloth applicator pad. Right from the syringe I squirt a very thin line the shape of a "M". With practice you can get about 5cc's per coat.
You waste very little product that way vs. the Zaino plastic bottle method. You might waste 1 little drop with the syringe.
**1 fluid ounce is about 29 cc's.
.I pour the Z2p or Z5p into the top of the syringe. I make sure the end is plugged with a small nail. I mix with ZFX if I need it. Squirt a couple shots of Z8. I then mix it all up and reinsert the plunger. The syringe method is much better for applying those thin layers of product onto a terry cloth applicator pad. Right from the syringe I squirt a very thin line the shape of a "M". With practice you can get about 5cc's per coat.
seagrasser
May 3, 2022 09:43 AM
Nickles
Sep 1, 2015 08:11 PM
