EXCESSIVE swirlmarks - HELP
Old Dec 2, 2003 | 09:34 PM
rsc6789's Avatar
Hey all! I have a 2003.5 Black sedan and take really good care of it. I wash it almost always once a week, yet most of the time my car is in the garage because I have to drive an Impala for work (haha the Impala doubles as my SUV). I take my car to a good car wash / detailer (or so ive heard.. Johnny's Car Wash and Detail in Sarasota, FL, anyone heard?) But, I have A TON of swirl marks and don't know what to do about them. I took it to the dealer and he said he was afraid to touch it!! He thought he would make it WORSE?!?! I am pissed off out of my mind and really want my G to be compleatly glossy! Can anyone help me out with this, or recommend an excellent detailer in the Sarasota, FL area (thats not amazingly expensive)? Any help would be greatly appreciated!!!
-RSC
03.5 S Black/Willow
<P ID="edit"><FONT class="small"><EM>Edited by rsc6789 on 12/02/03 06:37 PM.</EM></FONT></P>
Old Dec 2, 2003 | 09:52 PM
zorro's Avatar
Re: EXCESSIVE swirlmarks - HELP
zaino has a solution, I believe it's called Z5. I've heard very good things about it. Good luck.
G35 Coupe. Diamond Graphite, Graphite, Premium and wheel and Tire package. Zaino Baby.
Old Dec 3, 2003 | 04:18 AM
Xmax's Avatar
The reason you have tons of swirl marks is that the people at the detail shop or your self maybe is using towels that are hard and stiff....those kind of drying material you really want to avoid...try using chamois they are a lot better and the should not leave swirl marks on your car. Try using 3ms finish restorer....that stuff works wonders especially on swirl marks. Be aware that this stuff is about 6 bucks a pop, if that is to much on your wallet try using Mothers Finish Restorer/Paint cleaner...similar to 3ms but cheaper but also you have to work a little harder to make it work just as good as 3ms. Good luck.
Shift_DEZ' NUTS
www.midnightimpulse.com
Old Dec 3, 2003 | 08:50 AM
tkman00's Avatar
rsc6789,
if the swirls really are as bad as you say they are, then none of the above remedies will work. you'll need to bring it to a professional detailer to have them buff/polish them out. you can check autopia and ask if there's someone regional to you that can help. i'd imagine that it should cost no more than $200 to take care of it.
going forward, be aware of how you wash/dry your car. more than likely, both you and johnny's car wash installed those aftermarket swirls. take a look in the faq/diy section, there's a good read on how to wash/dry the car.
Old Dec 3, 2003 | 10:34 AM
GTR35's Avatar
I own a detail shop and i use Car polishes ultra hand glaze 2 and i also use Malco's Mag 2 this is the best solution for swilrs trust me on this i owed plenty of black cars and i use to go nuts just like you guys are doing
Old Dec 3, 2003 | 10:59 AM
tkman00's Avatar
gtr35,
glazes are fine. this g will be my 4th black car. and while i understand that filling swirls w/ glazes is works, i'd prefer to remove them since glazes will eventually break down causing the swirls to reappear.
if one doesn't mind just hiding swirls, and doing this a few times a year, then any glaze will take care of this. 3M imperial hand glaze is readily available at pep boys/autozone/etc, and should do the job nicely. personally i would opt for having the swirls removed by polishing w/ a machine, but then again, that's just me.
<P ID="edit"><FONT class="small"><EM>Edited by tkman00 on 12/03/03 08:04 AM.</EM></FONT></P>
Old Dec 3, 2003 | 01:00 PM
Premier's Avatar
tkman00 is right. If you want the swirl marks to be permanently removed, you'd need to get the exterior professionally detailed. That would be a quick fix......you wouldn't have to slave over dozens of chemicals and many hrs of labor to remove them and find out later that you were only temporarily hiding the swirls. Pay to get it done and then invest in some microfiber towels........and beware of using any dirty cloth to wash the car. Something as simple as a dirty bucket can cause much damage.
Pearl White 2003 Sedan & 2004 Coupe 6MT
Certified Window Tint & Detailing Specialist
Clearshield ("Clearbra") Authorized Dealer
Madico Authorized Dealer
www.machiii.net
Old Dec 7, 2003 | 08:00 PM
Hooby's Avatar
I live in Sarasota too, never been to Johnnys carwash yet with my G
Have you tried that new detail place off bee ridge near pops driving range?
Muski_G
Dec 1, 2023 11:11 AM
5150DS
Sep 26, 2015 07:47 PM
socaldavid
Sep 5, 2015 04:35 AM
andyg35c1
Aug 29, 2015 03:37 PM
roary35
May 27, 2003 05:24 PM
