Need Help - marks in the paint
Old Apr 11, 2007 | 03:18 AM
Gam3's Avatar
the color of my car is IP (which is also stated in my signature)..and around 6 or 7 when the sun was setting i looked at my paint under the light from the sun and i noticed when viewing it from a close distance ...there are marks in the paint..i think which were caused by a cotton towel i used once...so no the paint doesnt have large swirls in it or anything....and it seems that the only light i can see these imperfections is under that sunset lighting...when its mid-day and the sun is out seems like i cant see anything..well...i just needed some help on how to get my paint back to perfect...i have the whole zaino kit and havent used the Z5 (swirl and scratch remover) yet...will seee if that works...hopefully it does...or do you guys suggest i get a PC and use that...also maybe using some type of polish would help? ....or maybe taking it to a professional detail shop to get all the imperfections out and then from then on doing the waxing myself? ....im preparing to do a lot of mods to the car and i definitely need my paint back to looking picture perfect..thanks guys ...i appreciate the help
Old Apr 11, 2007 | 07:32 AM
redlude97's Avatar
Z5 doesn't remove swirls, it only hides them. Use meg's scratch-x for spot removal of swirling/scratches
Old Apr 11, 2007 | 03:14 PM
Gam3's Avatar
thnx redule97...ill look into getting scratch x...also should i just apply it by hand...or pc
Old Apr 11, 2007 | 06:30 PM
Detailed Image's Avatar
ScratchX is typically applied by hand. If this doesn't do the trick, I'd recommend looking in the Menzerna line of polishes, which are often regarded as some of the best on the market, especially if you have access to a Porter Cable. Let us know how you make out and if you have any questions on anything.
Good luck!
George @ Detailed Image
Old Apr 11, 2007 | 06:44 PM
redlude97's Avatar
if its the newly reformulated scratch-x, you can apply by hand or with a PC. If you have access to a PC, then there are better polishes probably. I was under the assumption you didn't have one
Old Apr 12, 2007 | 02:53 PM
Gam3's Avatar
redlude97 i dont have a pc...but im going to try out the z5 today and see how it turns out..the marks are definitely not obvious...its nearly impossible to see them when looking directly at the car...but im ****...and i look at everything from an up close view...just wanted to fill that stuff in...so if the z5 does nothing ill move on to the scratch x.....also thanks detailed image on your help as well
Old Apr 13, 2007 | 03:49 PM
bulldog25's Avatar
Z5 is a very good product. I'd do a couple of coats of Z5 then a coat of z2 and then a coat of quick detailer to give it some pop.
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Jan 31, 2016 07:14 AM
mbe32
Nov 13, 2015 11:09 PM
