Anyone use an orbiter?
Old May 25, 2007 | 12:08 PM
gymcshoe's Avatar
Anyone use an orbiter to wax your G? I'm using zaino wax. Was thinking an orbiter would help. Anyone have any personal experiences and pros/cons? Thanks
Old May 25, 2007 | 12:25 PM
max2k1's Avatar
You mean a random orb like PC ? There are quite a few folks on this forum that use PC.
I know Garnet Canuck uses one and so does picus .... many more for sure.
there is a detailing sub-forum -- this question might get more attention there
Old May 25, 2007 | 12:33 PM
GEE35FX's Avatar
I have one but I don't use it to apply Zaino since you waste so much of it on the pad when applying it. Zaino goes on very easy by hand, it is a total waste to use a PC for it.
Old May 25, 2007 | 02:41 PM
shawnost's Avatar
^+1. I agree that Zaino is very easy and quick to apply by hand and requires very little polish for a coat (about 0.5oz). You certainly could apply with a PC but as GEE35X stated you would be wasting a fair amount of polish. At the end of the day it's up to you since it's your car and your $.
Old May 25, 2007 | 04:35 PM
G-Whizzer's Avatar
Apply by hand - remove with the orbital...
Old May 25, 2007 | 04:47 PM
ttrank's Avatar
Grocery getter
^^+1
There you go!
Old May 25, 2007 | 08:22 PM
Garnet Canuck's Avatar
Traveling Administrator
I apply all of my sealants via PC simply because it allows me to apply them in a consistent manner. I will continue to apply sealants via my PC and carnubas by hand.
Old May 25, 2007 | 08:29 PM
RBull's Avatar
Rated M
^+1
Old May 25, 2007 | 08:47 PM
I'm the opposite. I'd much rather apply by PC and remove by hand. Applying your sealant via PC will give you a much more consistent result versus applying by hand.......IMO!
Old May 26, 2007 | 01:09 AM
LT1 SS's Avatar
I applied z2 with a pc. I managed to get three coats out of one zfx mixing bottle.
Old May 26, 2007 | 09:11 AM
kenchan's Avatar
i use my RO for polishing and applying wax. i remove wax by hand.
then at the very end (if i need it) i will use my wax removal bonnets on the
RO, but usually dont need it.
Old May 26, 2007 | 10:13 AM
RBull's Avatar
Rated M
Yes. It's not common to remove with a machine. Most good sealants and waxes remove very easily by hand.
Old May 27, 2007 | 04:11 AM
tod071's Avatar
I agree that PC application gives even application. But Zaino goes on very thin and applying with pc will definitely use much more product. I don't recommend application by pc on Zaino products. Apply with mf or applicator pad very very thin coats.
Detailed Image
Aug 30, 2008 08:11 PM
Detailed Image
Nov 19, 2007 11:21 AM
lllee
May 22, 2004 10:11 PM
cram
Mar 3, 2004 11:41 AM
