Spilled Touch-up Paint
Old Jul 8, 2007 | 08:26 PM
App6MT's Avatar
Littering and...
I am officially going to buy a 83 Iroc-z because I can't have anything nice without f'ing it up.
So I spilled some (ok like the whole bottle) touchup paint on the front of my car. I could only get some of it off and the rest is caked on there.
Any ideas?
Old Jul 8, 2007 | 09:37 PM
kvangil's Avatar
Maybe some rubbing compound. I spilled a small amount on my bumper, and was quickly able to get it out with turtle wax rubbing compound.
Old Jul 9, 2007 | 12:09 PM
kenchan's Avatar
scratch-x should take it all away.
Old Jul 9, 2007 | 12:27 PM
Pska's Avatar
just be careful; remember that the paint around what you're trying to work off is alot thinner. Maybe try a claybar first.
Old Jul 9, 2007 | 12:40 PM
redlude97's Avatar
try some paint thinner if the paint hasn't fully cured, it should remove it without harming the paint underneath
Old Jul 9, 2007 | 12:45 PM
Pska's Avatar
I wouldn't think paint thinner would be a good idea... does the clearcoat protect against it?
Old Jul 9, 2007 | 01:09 PM
redlude97's Avatar
paint thinner will not harm cured factory paint from my experience
Old Jul 9, 2007 | 01:56 PM
EricIsKlumzyee's Avatar
use paint thinner before it becomes fully cured like the members above said..
if you're good You can take it off with thiner and some FINE FINE FINE grit wet sand paper (wet with water please) and buff it afterwards but for now just use some thinner on a towel and do not apply pressure and wash the area when your done
thiner will take off factory paint if you rub against it or leave it on.
Old Jul 9, 2007 | 03:29 PM
App6MT's Avatar
Littering and...
How fine would you suggest? I've done wet sanding just not on a car and I don't know how much I trust myself. I have 2000 grit lying around from lapping my processor/heatsink.
Old Jul 9, 2007 | 07:53 PM
neal540's Avatar
ACT FAST, get your *** up and put paint thinner on it. If it doesnt work, try rubbing compound. If not, you may have to wet sand that biach. Post on autopia.org/forum if these dont work
Old Jul 9, 2007 | 08:16 PM
kvangil's Avatar
2000 grit should be fine enough. If you wetsand, then you may need rubbing compound afterward to get the shine back....Be careful though--too much sanding and rubbing compound, and you'll be staring at primer....Not that I speak from experience....
Old Jul 9, 2007 | 08:34 PM
App6MT's Avatar
Littering and...
Just wanted to thank everyone for the responses. I took it by an autoshop today and made an appointment for tomorrow.
However when I got home I was determined to get it myself and I did. I used Goo Gone Orange Blast (?). It removed it without a hitch, took alittle elbow grease though. Definitely do not use regular Goo Gone. My dad was trying to help, he used it on my grille and lifted the finish.
Oh well, mom said she would buy me a replacement. Now I don't know if I should order Klumzyee's or Ionic's
Old Jul 10, 2007 | 02:30 PM
kenchan's Avatar
hey shouldn't you be busy painting grills?
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Jan 31, 2016 07:14 AM
