Baked Brake Dust
Old Jul 30, 2007 | 08:35 PM
maxpusher's Avatar
20 Year Member
Baked Brake Dust
Hello,
I recently bought a '05 Infinity G35 with factory 18" sports rims. The problem is the rims are covered with brake dust and it won't come off.
I tried claying it and that didn't do much except make the surface real smooth. I sprayed some Simple Green and worked it in with a nylon brush and that didn't help. I then bought Meguiars Hot Rims all wheel cleaner and that didn't work either.
I was wondering what are some more aggressive products I could use without damaging the rims. I have heard of Poorboys Spray and Rinse Cleaner to be pretty aggressive (pH = 4).
What do you professional detailers use to get baked on dust off rims? Also, does anyone know if the G35 has clearcoat on the rims. Thanks.
Old Jul 30, 2007 | 10:36 PM
nsv's Avatar
nsv
I used Hydrofluoric Acid which works very good. It might be hard to get hold of, but you can purchase it online.
For the record, it should be handled with care, as it can be fatal.
Old Jul 30, 2007 | 10:42 PM
nsv's Avatar
nsv
Here is the link to a site where it can be purchased -
http://www.chemical-supermarket.com/...FQRDYQodOAbFbA
Again, if you have never handled Hydrofluoric Acid, please read the MSDS and required protective measures for use.
Old Jul 30, 2007 | 11:28 PM
thelurker29's Avatar
i would say some simple rubbing compund would do the trick...i think acid is a bit harsh...rubbing compund almost always gets anything off
Old Jul 30, 2007 | 11:33 PM
OCG35's Avatar
Originally Posted by maxpusher
Hello,
yes the OEM are clear-coated... many have had very good results from WheelWax...
Old Jul 31, 2007 | 01:41 AM
killerlexus's Avatar
use the orange gel that mechanics use, to wash grease of thier hands.
Old Jul 31, 2007 | 01:50 AM
ttrank's Avatar
Grocery getter
^+1
That works with a good brush.
Old Jul 31, 2007 | 11:57 AM
MidnightG35X's Avatar
That doesn't scratch at all? Most of those (Fast Orange, Gojo, etc) have pumice pellets in there. I haven't tried it, so I'm just wondering.
Old Jul 31, 2007 | 12:27 PM
use the white stuff WITH OUT the sand.
Old Jul 31, 2007 | 01:25 PM
ballisticus's Avatar
I don't think I have ever heard of a suggestion quite this bad. I work in the chemical industry and this stuff is without question DEADLY. The fumes alone will allow it into your blood and bones and you will suffer a long, miserable end. Anybody handling this is suited up, gloved to the armpits, and with a pressurized respirator. To use this as a cleaner is Darwin award stuff. I can't believe they even sell it to the public. Idiots are setting themselves up for legal problems.
Old Jul 31, 2007 | 01:32 PM
ScubaSteve312's Avatar
wow so closed minded, it deffinetly works just like replacing laundry detergent with gasoline
Old Jul 31, 2007 | 04:04 PM
KevinHeld's Avatar
I'd think someone working in the chemical industry would know that HF in low enough of a concentration can be safely used without respiratory protection. It's definitely not as safe as some other methods, but it will work well. 7 years ago when I worked in a detail shop, thats what we used. Just be smart, wear eye protection and gloves and use it outside. As was mentioned above, read MSDS and use your judgement.
Old Jul 31, 2007 | 04:13 PM
Jeff92se's Avatar
Red Card Crew
Pretty big risk for some brake dust. I'll pass:
Detailed Product Description:A colorless fuming liquid. Noncombustible. This is a strong and highly corrosive acid.Most commonly used in aluminum production, processing uranium and for etching glassand other silicon-based materials especially in semiconductor industry. Precautions:**This is probably one of the most dangerous industrial acids in existence**Attacks calcium in bones. Strong irritant to eyes and skin. Highly corrosive to skinand mucous membranes. Toxic by inhalation and ingestion. Will attack glass specificallyand generally any silicon-containing materials. Download, read, and fully understand the risks and precautions associated withthis substance before using.
Question though. What makes this stuff get the brake dust off and not attack the paint and aluminum?
Old Jul 31, 2007 | 04:23 PM
The link he supplied is for 49% concentrated HF. Spill a few ounces of this on your leg and see what happens. This poor guy did and he died an agonizing death 15 days later after they sawed of his leg. Your former employer clearly had your health in mind.
If your wheels are worth it, go right ahead.
http://www-safety.deas.harvard.edu/advise/accident.html
"A 37-year-old male laboratory technician was performing acid digestion of oil well core and ditch samples with 70% w/w concentrated hydrofluoric acid in a fume cupboard. He was believed to be seated when he knocked over a small quantity (100-230 ml) of hydrofluoric acid onto his lap, splashing both thighs. The only personal protective equipment (PPE) worn was two pairs of wrist length rubber gloves and a pair of polyvinyl chloride (PVC) sleeve protectors. As a result of the fact that the technician was working alone, it is unclear whether the spill was from the digestion cup or the 2-l bulk acid container.
The technician sustained burns to 9% of his body surface area, despite washing his legs with water from a makeshift plumbing arrangement that supplied water at 6 l. min -. No calcium gluconate gel was applied to the affected area and contaminated clothing was not removed during the flushing with water. Following flushing, the technician, who appeared to be in severe pain and shock, immersed himself in a chlorinated swimming pool at the rear of the workplace, where he remained for approximately 35-40 min before ambulance help arrived.
The injured man was hypothermic and hypocalacaemic on admission to an intensive care unit at a nearby hospital, and soon became unconscious. His condition continued to deteriorate despite subcutaneous injections of calcium gluconate and administration of intravenous calcium and magnesium. His right leg was amputated 7 days after the incident. He subsequently died from multi-organ failure 15 days after hydrofluoric acid spill."
Old Jul 31, 2007 | 04:27 PM
OCG35's Avatar
this thread is getting nutty... I work in an industry that deals with HazMat... I would not suggest for any reason dealing with HF or any other potentially volatile substance for something as simple as cleaning a vehicles wheel.
What the hell are you peopling thinking? There are tons of safe effective products on the market. Some better than others, which I think is why the OP asked the question... back-room chemists kooky recipes would just be ignored if you have any amount of intelligence.
If you are offended - re-read and think hard about the logic here. Buy the stuff that safely cleans the f-ing wheels. Why risk anything else.
