Adhesive on Headlight
Old Sep 8, 2007 | 11:01 AM
bu villain's Avatar
What is the best product/way to remove adhesive on your headlights. I ask because I have 3M tape residue from my eyelids and also some of the black headlight adhesive from when I took apart my lights.
It seems like goo gone or alcohol may damage the clear plastic and soap and water doesnt seem like it would be enough, especially for the black adhesive.
Thanks.
Old Sep 8, 2007 | 11:47 AM
exceldetail's Avatar
Wd-40.........
Old Sep 8, 2007 | 02:47 PM
bu villain's Avatar
hmm alright thanks. I may try that
Old Sep 9, 2007 | 01:09 AM
darich's Avatar
I'd try the goo gone, because it is a citrus cleaner. I wouldn't use rubbing alcohol or wd-40 for fear of fogging the lens. Then again, I am not sure what material the lens is made of. I just know that rubbing alcohol can fog some plastics.
Old Sep 9, 2007 | 01:52 PM
GR8TG35's Avatar
WD-40 will not hurt the plastic lense......Should remove most of the sticky residue, then wax with either Plastic polish or car wax.
Old Sep 10, 2007 | 05:59 PM
bu villain's Avatar
wd-40 didnt seem to be getting it off. I tried rubbing immediately and after leaving it on a few minutes to no avail. Might have to try the goo gone.
Old Sep 10, 2007 | 06:01 PM
MixturePinoy's Avatar
goo gone definitly works. I had a bunch of headlight seal melted all over mine, and what i did was place a paper towel on the sealant and let it stick to it. then i soaked the towel with goo gone, let it rest for a few minutes. got a microfiber towel and put some goo gone on that, removed the paper towel from headlight, and rubbed away the seal. no scratches or anything. good luck
Old Sep 10, 2007 | 11:35 PM
kernel's Avatar
SEC > Big 12
have u tried gently wetsanding?
Old Sep 11, 2007 | 10:24 AM
RBull's Avatar
Rated M
^ seems a little extreme before trying a few more safer methods.
Try a claybar with some quick detail lubricant.
Old Sep 16, 2007 | 11:49 AM
bu villain's Avatar
Goo Gone did the trick. Thanks
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
