Leather conditioner help needed !
Old Dec 9, 2007 | 03:46 PM
Bigguy2000's Avatar
Someone please solve problem of getting leather conditioner in the thousands of perforations in my '06 Coupes seats ! Since they are Graphite color the conditioner I tried (Meguiars) started turning each little hole white! I'm sure someone else has had this prob. Thanks in advance for reply's.
Old Dec 9, 2007 | 04:00 PM
Scrooge's Avatar
If it's hard stuff already in there. You need to softing it up by poking at the hole's with a tooth pick and then using a woolite(1:6) or APC(1:10) to loosing it up more and then vacuum it. It's going to take some time to remove everlast bit. I myself use all this tools to get my peforation in the seats clean:
Woolite1:6, PC with leather brush, Viynl leather brush, Toothbrush(meduim), Lexol leather ph cleaner, Wood toothpick's and a 5 hp vacuum.
I myself had the same probelm when I friend threw up in the back sit and it was a hot day and I was away from my house, So when I got back home the stuff alreay harden and I had to take out the back set to clean it. Took along time
Old Dec 9, 2007 | 05:58 PM
Bigguy2000's Avatar
Thanks for the reply. I have the perforations cleaned out. I need a product suggestion on what clean/condition product WON'T clog up the holes. Obviously the Meguairs being white in color was a bad idea on my part.
Old Dec 9, 2007 | 07:17 PM
miltoda's Avatar
I think there are some clear leather conditioners (spray bottles). I think armor all makes some. I know armor all isn't the best. But I've used it on occasions and it does a pretty good job of lifting dirt and hydrating leather. I think it's a little too shiny, but that side effect doesn't last all that long.
Old Dec 9, 2007 | 10:21 PM
Scrooge's Avatar
Lexol also make's a condtioner spray.
Old Dec 9, 2007 | 10:29 PM
Ionic's Avatar
Lexol is definitely a good product, I've been using it for years. Never had any of those problems.
Old Dec 9, 2007 | 10:33 PM
Da-G-SpoT's Avatar
Autopia.com has all the info you need.
Old Dec 10, 2007 | 05:01 AM
redlude97's Avatar
http://autopia.org/
Old Dec 13, 2007 | 09:47 PM
Da-G-SpoT's Avatar
Awwww same cr*p lol
Old Dec 14, 2007 | 07:43 AM
RBull's Avatar
Rated M
I use Lexol and don't have that problem.
Old Dec 14, 2007 | 01:22 PM
TOGWT's Avatar
Use a water-based product (will not block perforations with oil /cream)
The complex tanning process of chromed tanned hides results in the fat liquoring and oils necessary to keep the hide soft and pliable being locked in, this is often further sealed by a durable polyethylene covering to protect the hide from abrasion from clothing as well as the dust / dirt introduced by the vehicle’s AC system.
This type of automotive upholstery finish should not be considered a natural leather hide as far as care and its maintenance is concerned, but treated as a vinyl, only requiring that you maintain its moisture and protect it from ultra violet (UV) radiation. A water-based cleaner will permeate the polyurethane covering as its molecules are much smaller.
Water-based coatings (polyurethane) react negatively when oil or a petroleum based product is applied to them, basic chemistry; sooner or later oil or petroleum distillates will deteriorate the top. Most leather conditioners are formulated with oils and will do more harm than good and are totally unnecessary on finished and / or covered leather.
Old Dec 14, 2007 | 01:24 PM
patman530's Avatar
i use the cheapo clearner/conditioner set they sell at costco and it works perfectly
Old Dec 14, 2007 | 01:35 PM
redlude97's Avatar
+1, 303 aerospacer protectant is all I use on my leather seats, I treat them as vinyl like the rest of the interior
Old Dec 17, 2007 | 07:57 PM
Beebo's Avatar
where can you buy it?
Old Dec 17, 2007 | 07:59 PM
redlude97's Avatar
Oops, I meant 303 aerospace protectant. http://www.detailedimage.com/303-M2/...rotectant-P12/
