plastic
Old Mar 5, 2008 | 02:12 PM
kavehdr1983's Avatar
plastic
Hi guys,
is there something to apply on the dashboard and door areas where there is only plasitc? (or is it leather which I doubt it?) Also for the plastic rubber that goes arround the door, etc. I have a G35 6MT coupe and the window sits on that rubber around the door frame, so I don't know if you put something on that might stain the glass. Correct me of I am wrong.
Kaveh
Old Mar 5, 2008 | 02:21 PM
Scrooge's Avatar
You can use 303 aerospace protectant or any other good protectant that good for rubber,plastic or viynl. Also try to put some protect on the rubber part not the felt side.
Old Mar 5, 2008 | 04:02 PM
Any feedbacks on Armroil?
So don't use it on where the glass touces the plastic? (but even that areas seems to be in need of protection).
Kaveh
Old Mar 5, 2008 | 05:15 PM
never gone's Avatar
303 is good stuff. Eagle One Nano Protectant is good too.
Old Mar 5, 2008 | 07:51 PM
Scrooge's Avatar
Kaveh
Your see one side be felt (window side) and the other side be the part your talking about.
Old Mar 6, 2008 | 01:42 AM
Joyriide1113's Avatar
303 Aerospace protectant, as mentioned, is great. It is water-based and offers UV protection from the sun. It also dries to the touch leaving a non greasy matte shine on the surface.
Like anything, prep is key, so make sure whatever surface is clean. Woolite mixed with water 1:1 is a great interior cleaning solution for all surfaces including leather.
Old Mar 6, 2008 | 03:24 PM
Scrooge's Avatar
You use 1:1 of woolite mixture. Do you have a soap film on the interior piece after your done. Cause I remember the dilution ratio was 1:6 to 1:10 to clean interior panels and leather.
Old Mar 6, 2008 | 04:33 PM
redlude97's Avatar
I use a 1:10 dilution, and now with their concentrated formula, its closer to 1:15-1:20
Old Mar 6, 2008 | 05:19 PM
Scrooge's Avatar
Which one are you using. Im use this woolite for delicates:
Old Mar 6, 2008 | 05:49 PM
redlude97's Avatar
I dunno, I buy a big tub of it from costco. I use it for washing my MF's also
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Thebaws11
Nov 30, 2016 12:54 PM
lavtxa
Sep 21, 2015 11:51 AM
Jon81035
Sep 16, 2015 04:58 PM
